[AG-TECH] libcrypto.so.2 not found.
Adam Taylor
accessgrid at ulm.edu
Fri Oct 29 14:20:20 CDT 2004
It looks like to me you need to install openssl on your system. As far as I
know, that provides that library.
Adam Taylor
Computing Center
University of Louisiana at Monroe.
-----Original Message-----
From: owner-ag-tech at mcs.anl.gov [mailto:owner-ag-tech at mcs.anl.gov] On Behalf
Of Pritesh
Sent: Friday, October 29, 2004 2:03 PM
To: ag-tech at mcs.anl.gov; ag-users at mcs.anl.gov
Subject: [AG-TECH] libcrypto.so.2 not found.
hi,
i'm trying to build accessgrid on NetBSD platform. i have the binaries which
are listed below:
collinsia: {116} ls
AGNodeService.py NodeManagement.py VenueManagement.py
AGServiceManager.py NodeSetupWizard.py VenueServer.py
BridgeServer.py QuickBridge agpm.py
CertificateRequestTool.py VenueClient.py certmgr.py
I have python version installed which is present at the following location :
/home/psham/pkg/bin/python2p2 . Its called python2p2 as the python 2.2.3
version is compiled with pthreads.
i've got optik, fpconst and other python packages installed at the following
/home/psham/pkg/lib/python2p2/site-packages
this is the problem that i'm facing:
collinsia: {117} python2p2 AGNodeService.py
Traceback (most recent call last):
File "AGNodeService.py", line 28, in ?
from AccessGrid.Toolkit import Service
File "/home/psham/pkg/lib/python2p2/site-packages/AccessGrid/Toolkit.py",
line 22, in ?
from AccessGrid.Security import CertificateManager
File
"/home/psham/pkg/lib/python2p2/site-packages/AccessGrid/Security/Certificate
Manager.py", line 48, in ?
from OpenSSL_AG import crypto
File "/home/psham/pkg/lib/python2p2/site-packages/OpenSSL_AG/__init__.py",
line 11, in ?
import rand, crypto, SSL
ImportError: Shared object "libcrypto.so.2" not found
its finding the python packages /home/psham/pkg/lib/python2p2/site-packages
properly, but fails when it tries to find libraries. could somebody help me
in case i'm doing anything wrong or is it that there's a specific place
where the libraries should go.
Cheers,
Pritesh
Join Excite! - http://www.excite.com
The most personalized portal on the Web!
More information about the Kenstest
