[AG-TECH] New agtk ebuilds
Ti Leggett
leggett at mcs.anl.gov
Thu Aug 26 09:30:13 CDT 2004
You must run the /usr/lib/gpt-3.0/sbin/gpt-postinstall and all that
before globus is fully configured. I try to do as much automatically,
but there's somethings that need user input (bleh).
On Thu, 2004-08-26 at 08:34, Martin Polak wrote:
> Ti Leggett wrote:
> > We've updated the agtk gentoo ebuild and also create a new cvs ebuild.
> > The cvs ebuild will do a cvs checkout and build the package from that.
> > It should be a very helpful addition to those of you like bleeding edge
> > constantly.
> > The 2.3_beta ebuild should live in $PORTDIR_OVERLAY/ag-libs/agtk
> > and the cvs ebuild should live in $PORTDIR_OVERLAY/ag-libs/agtk-cvs
> > Notice that these are separate packages and you can't have them both
> > installed at the same time.
> > Before you can use them you'll need to do either:
> > ebuild $PORTDIR_OVERLAY/ag-libs/agtk/agtk-2.3_beta1-r1.ebuild digest
> > or
> > ebuild $PORTDIR_OVERLAY/ag-libs/agtk-cvs/agtk-cvs-2.3.ebuild digest
> > Please let us know if you have any problems or feedback.
> The ebuild fails for me when emerging
> dev-python/pyglobus-0.9.7-r1
> with the following output:
> emerge ag-libs/agtk
> Calculating dependencies ...done!
> >>> emerge (1 of 10) dev-python/pyglobus-0.9.7-r1 to /
> >>> md5 src_uri ;-) pyGlobus-0.9.7.tar.gz
> >>> Unpacking source...
> >>> Unpacking pyGlobus-0.9.7.tar.gz to
> /var/tmp/portage/pyglobus-0.9.7-r1/work
> >>> Source unpacked.
> Checking for which modules to build
> Checking the util module
> Missing dependency to build the util package.
> This package is required to build all of pyGlobus.
> The following is the error message from globus-makefile-header.
> ('No packages were found that matched your query!\n',)
> Now exiting from the build.
> !!! ERROR: dev-python/pyglobus-0.9.7-r1 failed.
> !!! Function distutils_src_compile, Line 38, Exitcode 255
> !!! compilation failed
> Any ideas?
More information about the Kenstest
