[AG-TECH] New agtk ebuilds
Martin Polak mpolak at gup.jku.at
Thu Aug 26 08:34:02 CDT 2004
Ti Leggett wrote:
> We've updated the agtk gentoo ebuild and also create a new cvs ebuild.
> The cvs ebuild will do a cvs checkout and build the package from that.
> It should be a very helpful addition to those of you like bleeding edge
> constantly.
> The 2.3_beta ebuild should live in $PORTDIR_OVERLAY/ag-libs/agtk
> and the cvs ebuild should live in $PORTDIR_OVERLAY/ag-libs/agtk-cvs
> Notice that these are separate packages and you can't have them both
> installed at the same time.
> Before you can use them you'll need to do either:
> ebuild $PORTDIR_OVERLAY/ag-libs/agtk/agtk-2.3_beta1-r1.ebuild digest
> or
> ebuild $PORTDIR_OVERLAY/ag-libs/agtk-cvs/agtk-cvs-2.3.ebuild digest
> Please let us know if you have any problems or feedback.
The ebuild fails for me when emerging
dev-python/pyglobus-0.9.7-r1
with the following output:
emerge ag-libs/agtk
Calculating dependencies ...done!
 >>> emerge (1 of 10) dev-python/pyglobus-0.9.7-r1 to /
 >>> md5 src_uri ;-) pyGlobus-0.9.7.tar.gz
 >>> Unpacking source...
 >>> Unpacking pyGlobus-0.9.7.tar.gz to
/var/tmp/portage/pyglobus-0.9.7-r1/work
 >>> Source unpacked.
Checking for which modules to build
Checking the util module
Missing dependency to build the util package.
This package is required to build all of pyGlobus.
The following is the error message from globus-makefile-header.
('No packages were found that matched your query!\n',)
Now exiting from the build.
!!! ERROR: dev-python/pyglobus-0.9.7-r1 failed.
!!! Function distutils_src_compile, Line 38, Exitcode 255
!!! compilation failed
Any ideas?
Dipl.-Ing.
Martin Polak
Institute of Graphics and Parallel Processing
Johannes Kepler University Linz
Altenbergerstrasse 69
A-4040 Linz, AUSTRIA, EUROPE                 ________  ______
T 627                                       / ____/ / / / __ \
phone: +43 732 2468 8884                   / / __/ / / / /_/ /
fax: +43 732 2468 9496                    / /_/ / /_/ / ____/
mobile: +43 699 112 02 493                \____/\____/_/
email: mpolak at gup.jku.at              http://www.gup.uni-linz.ac.at/
More information about the Kenstest mailing list
