[AG-TECH] Cant store node configuration AGTK 2.3
Randy Groves
randy.groves at boeing.com
Wed Aug 11 10:19:42 CDT 2004
This bug has been reported. There is a workaround, till the bug gets
fixed. On Windows, my experience is that if you try to store to an
existing file, it will work. So you could store the new configuration back
to the 'defaultWindows' configuration, or you could create an empty file in
C:\Documents and Settings\USER\Application Data\AccessGrid\Config\nodeConfig
(Where 'USER' is your Win2K/XP user). Then when you start up the client,
and try to save the configuration, you will see the empty file name
listed. You can then save to this file. It will prompt as to whether you
want to overwrite this file - select yes (or OK, I don't remember).
-randy
At 04:28 AM 8/11/2004, Natalia Costas Lago wrote:
>Hi everybody,
>I have a weird problem, I installed AGTK 2.3 in Fedora Core (the video PC,
>the display PC with the venue client is under Win 2k), I add the service
>manager and video producer service in the venue client and, when i try to
>store the configuration the client hangs. Am I doing something wrong?
>I tried to start the Venue client on the Linux PC, but I get a few trouble,
>if I start the script AGServiceManager.py by myself (no personalNode
>option) the venue client hangs, when started as a personal node I can add a
>service manager at port 11000 but the services box is empty!
>Do I have to add any update or something??
>Any help is greatly appreciated.
>Natalia Costas Lago
>mailto: natalia at cesga.es
>Centro de Supercomputacion de Galicia (CESGA)
>Avenida de Vigo, s/n Campus Sur
>15705 Santiago de Compostela - SPAIN
>Tel: +34 981 56 98 10
>Fax: +34 981 59 46 16
>http://www.cesga.es/
More information about the Kenstest
