[AG-TECH] AG2.2 - Venue Client
Thomas Uram
turam at mcs.anl.gov
Wed Aug 11 08:48:29 CDT 2004
Hi Anne:
The error you identified shouldn't prevent the node setup wizard from
starting. There should be another indication of problem in that
logfile; if you don't see it, you should file a bug for the node setup
wizard in our bugzilla (http://bugzilla.mcs.anl.gov/AccessGrid) and
include the logfile.
The problem you encountered with rat and vic not starting is due to a
difference in the personal node setup between 2.1 and 2.2. You should
be able to get the media tools working by building a new node configuration:
- Start the VenueClient
- Select Preferences->ManageMyNode
- Add the service manager at localhost 11000
- Add services (audio, videoconsumer, videoproducer) to the service manager
- Save the node config as the default
It should then work each time you start the venue client.
Tom
Anne M. Hammond wrote:
>I had installed AG2.2, after installing ActiveState Active Python 2.3
>and wxPython 2.4 for Python 2.3.
>I am using an IBM ThinkPad with a Logitech camera (which works).
>When I bring up the Venue Client, the Rat and Vic thumbnails do not
>come up. Audio and Video are enabled.
>I tried twice to start the Node Setup Wizard. It gets 80% into
>the green startup bar, and then gives a messages that it cannot
>start the Wizard.
>I have run the Venue Client in debug mode. The first ERROR is
>venueclient.py:317 ERROR Error loading default configuration.
>Is there a way to troubleshoot this, or do I need to fall back to
>AG2.1? If I need to fall back, do I need to get the older versions
>of Active Python and wxPython??
>Thanks in advance.
>Anne Hammond
>University of Colorado at Boulder
More information about the Kenstest
