itaps-parallel Two options from today's iMeshP phone conference
Jason Kraftcheck kraftche at cae.wisc.edu
Mon Jul 19 13:14:17 CDT 2010
Mark Beall wrote:
> On Jul 19, 2010, at 1:50 PM, Jason Kraftcheck wrote:
>> Mark Beall wrote:
>>> On Jul 19, 2010, at 1:32 PM, Jason Kraftcheck wrote:
>>>>> I'd say that using the root set to mean both "no set" and "the set
>>>>> that
>>>>> contains everything" is confusing. In iMesh_loadMesh (and most other
>>>>> places I saw when I looked quickly) you can say that it means
>>>>> "everything in the instance", which is the same as the root set.
>>>>> However
>>>>> if there are places (now or in the future) where there is a meaningful
>>>>> difference between the two things, that usage could become
>>>>> problematic.
>>>> How does it mean 'the set that contains everything' in the *load*Mesh
>>>> case?
>>> Since the root set does contain everything and that's the set you're
>>> passing, thus you did add the entities into the set you passed in. Yes,
>>> the mesh entities get added to the root set anyhow, but it's at least a
>>> little consistent (although I do think that passing a NULL set here
>>> would be more clear).
>> And how is this different than the createEnt case?
> Since we're trying to specify the part that the entity goes into in
> parallel. It's been pretty clearly established in the past that in
> iMesh/iMeshP parts are not entity sets (even though they may be in some
> implementations) even though there are a few entity set functions that
> are currently "overloaded" to also be able to take in parts (changing
> that was brought up at one point, I don't recall whether that ever was
> discussed)
> Really this function should take in a part handle, not an entity set.
> The definition for iMeshP_PartHandle could easily be moved into iMesh.h.
> Should also at that time, changing it so that's it's not typedefed to
> iBase_EntitySetHandle.
But in the specific case of passing the root set as a 'null' handle to
createEnt, how is the behavior different then when the root set is used in
that way for loadMesh?  In both cases the mesh is 'added' to the root set,
which is essentially a no-op because everything is in the root set anyway.
- jason
More information about the itaps-parallel mailing list
