itaps-parallel Two options from today's iMeshP phone conference
Mark Beall mbeall at simmetrix.com
Mon Jul 19 13:11:00 CDT 2010
On Jul 19, 2010, at 1:50 PM, Jason Kraftcheck wrote:
> Mark Beall wrote:
>> On Jul 19, 2010, at 1:32 PM, Jason Kraftcheck wrote:
>>>> I'd say that using the root set to mean both "no set" and "the
>>>> set that
>>>> contains everything" is confusing. In iMesh_loadMesh (and most
>>>> other
>>>> places I saw when I looked quickly) you can say that it means
>>>> "everything in the instance", which is the same as the root set.
>>>> However
>>>> if there are places (now or in the future) where there is a
>>>> meaningful
>>>> difference between the two things, that usage could become
>>>> problematic.
>>> How does it mean 'the set that contains everything' in the
>>> *load*Mesh
>>> case?
>> Since the root set does contain everything and that's the set you're
>> passing, thus you did add the entities into the set you passed in.
>> Yes,
>> the mesh entities get added to the root set anyhow, but it's at
>> least a
>> little consistent (although I do think that passing a NULL set here
>> would be more clear).
> And how is this different than the createEnt case?
Since we're trying to specify the part that the entity goes into in
parallel. It's been pretty clearly established in the past that in
iMesh/iMeshP parts are not entity sets (even though they may be in
some implementations) even though there are a few entity set functions
that are currently "overloaded" to also be able to take in parts
(changing that was brought up at one point, I don't recall whether
that ever was discussed)
Really this function should take in a part handle, not an entity set.
The definition for iMeshP_PartHandle could easily be moved into
iMesh.h. Should also at that time, changing it so that's it's not
typedefed to iBase_EntitySetHandle.
mark
More information about the itaps-parallel mailing list
