itaps-parallel Two options from today's iMeshP phone conference
Jason Kraftcheck
kraftche at cae.wisc.edu
Mon Jul 19 11:53:42 CDT 2010
Saurabh Tendulkar wrote:
>>> I think for A, we proposed that the argument be NULL in case of serial.
>>> If we want no restriction in iMesh, then maybe we can instead pass an
>>> array of entity sets to iMesh_createEnt, and then in iMeshP stipulate
>>> that one of them has to be a part.
>> Logically null. Not literally 'NULL' (a bit-wise zero value). Not all
>> implementations use pointer-based handles, and therefore zero is not an
>> invalid handle value for all implementations. The closest thing we
>> have to
>> a logical null is the root set (as everything goes into the root set
>> anyway.)
>> - jason
> Don't they have to use pointer-based handles,
No.
> since
> iBase_EntitySetHandle is typedef'd as:
> typedef struct iBase_EntitySetHandle_Private* iBase_EntitySetHandle;
> in iBase.h?
The fact that a pointer is used in the typedef for a set handle does not in
any way restrict implementations to using pointers, nor is it intended to.
More information about the itaps-parallel
