itaps-parallel This week's conference call
Mark Shephard shephard at scorec.rpi.edu
Wed May 26 14:09:35 CDT 2010
In looking over the use cases I do not see anything in them that
introduces anything that is beyond things that have to be done is stuff
we are already doing for parallel mesh adaptation (including boundary
layers). To the best of my understanding the questions we have have been
discussing really do not influence on how to attack these problems. The
issues we have been discussing continue to be of importance to how
efficient implementations can be.
Note - writing up the details of doing the use cases would be pretty
extensive and time consuming.
seol at scorec.rpi.edu wrote:
> Karen,
> The compromise proposal will work fine with the FMDB.
> One question is that the use case, efficiency, and the ease of handling of
> the entity ownership if we allow the user to specify the owner part of
> mesh entity.
> It's not clear to me what's our scenario between #1 and #2.
> #1 we assume that the owner part of the entity is automatically determined
> at time of entity creation by default and will allow some exceptional case
> where the user can specify the owner part for specific entities
> #2 for every entity, the owner part shall be specified explicitly.
> In case of the FMDB, the owner part is determined based on the partition
> model classification to which each entity belongs so the application has
> no right to change the entity ownership at the moment.
> Seegyoung
>> Since we rescheduled the iMeshP conference call (now Thursday, May 27 at
>> 8am
>> PDT), I'll ask you to do some extra work.  Please consider the attached
>> use
>> cases (drafted by Tim -- thanks, Tim!).  For each case, consider whether
>> the
>> proposal works, particularly in the context of your implementation.  We'll
>> discuss the proposal and use cases on Thursday.
>> Thanks.
>> Karen
More information about the itaps-parallel mailing list
