itaps-parallel Notes from today's meeting
Mark Beall mbeall at simmetrix.com
Tue Apr 13 10:07:18 CDT 2010
Jason,
Assuming that the two partitions are not 100% correlated (the
interface elements are not on the same processors as their associated
volume elements), I think you have the same problem with the current
design. The interface elements will be copies on different processors
in the second partition. If someone has a way to avoid this, feel free
to point it out since it's the basis of my entire argument here.
If the two partitions are 100% correlated, then it's the same as if
you were doing it in serial and in that case I don't see that you
would want to use a partition to represent the interface elements,
you'd just use a mesh entity set.
mark
On Apr 13, 2010, at 10:24 AM, Jason Kraftcheck wrote:
> Mark,
> I think that having one iMesh instance per Part would be problematic
> for
> "contact"-type problems.  If I understand the nature of the problem
> correctly, there are two partitioning of the mesh: one that
> distributes
> volume elements and one that distributes 2D elements on interfaces.
> If
> there were multiple (for simplicity lets say two) iMesh instances
> for a
> single process where one contains the volume elements and one
> contains the
> 2D elements then there would be no way to obtain information about the
> relation between the 2D elements and the volume elements.
> - jason
More information about the itaps-parallel mailing list
