itaps-parallel Notes from today's meeting
Mark Shephard
shephard at scorec.rpi.edu
Tue Apr 13 09:53:24 CDT 2010
Jason,
It is a strong function of how one would support the mesh in parallel. I
do know how I would do partitioning and dynamic re-partitioning (to
account for contact evolution) for efficient parallel simulation using
iMeshP's FMDB implementation and the issue of where the mesh instance is
defined creates no problem at all.
Jason Kraftcheck wrote:
> Mark,
> I think that having one iMesh instance per Part would be problematic for
> "contact"-type problems. If I understand the nature of the problem
> correctly, there are two partitioning of the mesh: one that distributes
> volume elements and one that distributes 2D elements on interfaces. If
> there were multiple (for simplicity lets say two) iMesh instances for a
> single process where one contains the volume elements and one contains the
> 2D elements then there would be no way to obtain information about the
> relation between the 2D elements and the volume elements.
> - jason
More information about the itaps-parallel
