itaps-parallel Questions about iMeshP
Mark Shephard shephard at scorec.rpi.edu
Tue Dec 15 09:34:15 CST 2009
Saurabh,
SCOREC has a partial implementation that supported some mesh adaptation
(no classification since we are still hoping for a direct way to do it).
With Ting on leave, Alex and Seegyoung are the best contacts. As we go
forward Seegyoung will be the key person.
Saurabh Tendulkar wrote:
> Hi,
> We are trying to implement the iMeshP interface to our software. We have
> the following questions and are hoping someone could help us with these:
> 1. What does the mesh instance represent in iMeshP? Is it essentially
> the on-process subset of entities of some global mesh? Where does the
> control of the global mesh lie in this case? It does not appear to be
> with the partition, as there can be multiple partitions of the same mesh.
> 2. It appears that the mesh contains the entities and it is the
> partition that controls how the entities lie in parts. This seems to
> mean that an entity can be in the mesh but not in a part (for example,
> when a part that contains entities is deleted). Is this fundamentally
> disallowed? Because various aspects of iMeshP are not defined if this is
> allowed. For example, if the entity was owned by the part that was
> deleted, who owns the entity now? And, how does one know whether an
> entity can be deleted from the mesh (next question)?
> 3. Who controls the deletion of entities when they are no longer needed
> on-process - eg. if they are migrated away, especially while keeping in
> mind that there may be multiple partitions (the entity may be needed on
> one and not on another).
> 4. It is mentioned that a part can act as an entityset. Since entitysets
> can have parent-child and containment relationships with other
> entitysets, does this mean that parts need to have them too? If so, it
> is undefined what this means with respect to the partitioning. If not,
> what is the expected course of action when a part is used in an iMesh
> entityset function call which would result in a hierarchical relationship?
> 5. Is there an already existing implementation and a set of compliance
> tests that can shed any light on these questions?
> Thank you.
> saurabh
More information about the itaps-parallel mailing list
