itaps-parallel Questions about iMeshP
Saurabh Tendulkar
saurabh at simmetrix.com
Tue Dec 15 09:25:57 CST 2009
We are trying to implement the iMeshP interface to our software. We have the
following questions and are hoping someone could help us with these:
1. What does the mesh instance represent in iMeshP? Is it essentially the
on-process subset of entities of some global mesh? Where does the control of the
global mesh lie in this case? It does not appear to be with the partition, as
there can be multiple partitions of the same mesh.
2. It appears that the mesh contains the entities and it is the partition that
controls how the entities lie in parts. This seems to mean that an entity can be
in the mesh but not in a part (for example, when a part that contains entities
is deleted). Is this fundamentally disallowed? Because various aspects of iMeshP
are not defined if this is allowed. For example, if the entity was owned by the
part that was deleted, who owns the entity now? And, how does one know whether
an entity can be deleted from the mesh (next question)?
3. Who controls the deletion of entities when they are no longer needed
on-process - eg. if they are migrated away, especially while keeping in mind
that there may be multiple partitions (the entity may be needed on one and not
on another).
4. It is mentioned that a part can act as an entityset. Since entitysets can
have parent-child and containment relationships with other entitysets, does this
mean that parts need to have them too? If so, it is undefined what this means
with respect to the partitioning. If not, what is the expected course of action
when a part is used in an iMesh entityset function call which would result in a
hierarchical relationship?
5. Is there an already existing implementation and a set of compliance tests
that can shed any light on these questions?
Thank you.
saurabh
More information about the itaps-parallel
