itaps-parallel [Fwd: **** iMesh.h and iBase.h changes ****]
Jason Kraftcheck
kraftche at cae.wisc.edu
Tue Jan 20 14:35:15 CST 2009
Ting Xie wrote:
> Hi Jason,
> We still do not know what are indices of adjacent entities in the new
> proposed function. Thus we make a simple example to demonstrate the
> problem, and try to clarify what are the inputs and outputs. Please
> correct me if you find any mistakes. Thanks.
See below.
> The attached is a simple mesh picture of two adjacent hexes. We call
> iMesh_getAdjEntIndices to get two following requests.
> 1. To get adjacent edge indices for the hexes
> INPUT: type=region, topo=hex, adj_type=edge
> OUTPUT:
> hex_handles: H1, H2
> adj_edge_handles: e1, e2, ..., e12, e1', e2', ..., e12'
The above is not correct. The hexes will share some edges, so the resulting
list would presumably contain 20 rather than 24 edges.
> adj_indices: 1, ..., 12, 1', 2', ..., 12'
That is not correct. Why would we return the same sequence of 1...offset[i]
for each element? All values in this list are indices into
adj_edge_handles. 16 of the values in the range [0..19] will occur exactly
once. 4 will occur twice, for the 4 edges that are shared by both hexes.
> offset: 0, 12, 24
> 2. To get adjacent vertex indices for the hexes
> INPUT: type=region, topo=hex, adj_type=vertex
> OUTPUT:
> hex_handles: H1, H2
> adj_edge_handles: v1, v2, ..., v8, v1', v2', ..., v8'
Again, this list will not contain any duplicates. If the two hexes share
two vertices, the handle for that shared vertex will occur exactly *once* in
the list.
> adj_indices: 1, ..., 8, 1', 2', ..., 8'
This is wrong, too. Perhaps you are confused by the mistake where
adj_indices is declared to be of type iBase_EntityHandle** when it should be
int**.
> offset: 0, 8, 16
> Since we do not know what are adj_indices. We guess that it has two options:
> (1) 1,..., 8
> (The order of adjacent edges local to the hex, should that start from 0 or
> 1? If this is the case, we do not have any problem. )
> (2) the unique integer ids of the edges in the mesh
> (If mesh database has dynamic storage because of mesh modification, like
> FMDB, and it does not store the unique ids for entities, what should
> return in the adj_indices array? )
It is neither of these. In your second example adj_edge_handles contains
all the vertices that are in either of the two hexes, without duplicates.
adj_indices contains 8 values for each hex. For each of the 8 vertices
adjacent to the hex, the value in adj_indices in the index into
adj_edge_handles where the handle for the corresponding vertex is stored.
The comment from the original source was:
*\param adj_entity_indices For each entity in 'entity_handles', the
* adjacent entities of type
* 'entity_type_requested', specified as
* indices into 'adj_entity_handles'. The
* values are concatenated into a single
* array in the order of the entity handles
* in 'entity_handles'.
- jason
More information about the itaps-parallel
