itaps-parallel Asynchronous functions in parallel interface
Onkar Sahni osahni at scorec.rpi.edu
Fri Oct 10 17:01:43 CDT 2008
I agree with these.
On documentation we may want to indicate (somewhere), common use case
scenarios for asynchronous iMeshP functions that may help
applications/services to understand the provided functionality and its
need.
- Onkar
> Tim Tautges wrote:
>> Conclusion:
>> After discussing after Lori hung up, we concluded that:
>> 1) Asynchronous calls are still needed and useful for iMeshP, for
>> various reasons.
>> 2) We should document the fact that although some amount of work can be
>> done after the asynchronous iMeshP call returns, there may be a
>> non-negligible amount of work that needs to be completed synchronously
>> (i.e. after the application calls a wait or test iMeshP function).
> The only sane way to avoid race conditions with the current API is to
> update
> the data when the application calls the wait/poll/test method.  It should
> be
> documented that the data is updated only for complete requests and only
> when
> a wait/poll/test function is called for that completed request.  Given
> that,
> it should be apparent to the application developer that any computational
> cost related to assimilating the data from an asynchronous communication
> will be incurred during the wait/poll/test call.
> - jason
>> - tim
>> Onkar Sahni wrote:
>>> I do not think this is true that "asynchronous calls are really
>>> synchronous", that is irrespective of the (below mentioned) ways it is
>>> handled either by OS-level parts of MPI or mesh-library-level threads
>>> (I
>>> do not think any forking is necessary at iMesh level by
>>> implementations,
>>> one may choose to do that way but many parallel systems do not allow
>>> forking like IBM BG/L, Cray XT3 and I think its limited on IBM BG/P).
>>> What MPI does and how it interacts with OS should not dictate the way
>>> we
>>> provide functionality.
>>> On Jason's proposal, I do not recall discussion on this (I may have
>>> missed
>>> it) and I do not really see a reason why two tags (source and
>>> destination)
>>> are needed.
>>> We can discuss more details on it via emails but before detailed email
>>> discussions I would instead recommend to schedule a phone conference to
>>> discuss these issues (if others think it is required).
>>> - Onkar
>>>> Hi all,
>>>>    Thinking more about Jason's proposal lead me to a really important
>>>> question about our parallel interface.  If we're proposing to have
>>> asynchronous functions like iMeshP_migrateEntity which return a request
>>> handle, with the application calling the test or wait functions to test
>>> whether a request has finished, where is the code which is executing
>>> that request running?  In the case of MPI, there is presumably some
>>> interaction with the OS, which is acting autonomously to fill buffers,
>>> transfer them to other processors, etc.  On large parallel systems
>>> that's handled by the OS-level parts of MPI; on workstations or
>>>> clusters, that's probably done by some other thread or process running
>>> on each node (or asynchronous calls are really synchronous).  For
>>> imesh,
>>> though, are any of the implementations able to do that kind of forking?
>>>>   I know MOAB never will.  In that case, I think asynchronous calls to
>>>> iMeshP don't make sense, or they only make sense if they're just
>>> pass-through functions to MPI, in which case they're superfluous.  I
>>> think it's down in the implementation where asynchronicity is used.
>>> For
>>> example, when exchanging tags of owned entities, that function can
>>> initiate and wait for multiple asynchronous messages.  Comments?
>>>> - tim
>>>> ================================================================ "You
>>> will keep in perfect peace him whose mind is
>>>>    steadfast, because he trusts in you."               Isaiah 26:3
>>>>               Tim Tautges            Argonne National Laboratory
>>>>           (tautges at mcs.anl.gov)      (telecommuting from UW-Madison)
>>> phone: (608) 263-8485      1500 Engineering Dr.
>>>>             fax: (608) 263-4499      Madison, WI 53706
> "A foolish consistency is the hobgoblin of little minds" - Ralph Waldo
> Emerson
More information about the itaps-parallel mailing list
