itaps-parallel Comments on Tutorial Slides
Lori A. Diachin
diachin2 at llnl.gov
Fri Sep 19 00:00:28 CDT 2008
Thanks Karen! Great catches. I made all the corrections (and found
several more of those funky end ")" ).
Tim, do you have any corrections for me on the SIDL file examples?
Lori
At 10:47 AM 9/18/2008, Devine, Karen D wrote:
>Lori:
>The tutorial slides look quite good! Thank you for your effort putting them
>together.
>I noticed a few details; I was looking at file
>ITAPS_SC08_Tutorial_Draft-09-16.pdf.
>- In the figure on slide 7 (Unstructured Meshes on Parallel Computers), the
>labels on the figure are slightly garbled in the PDF version. In
>particular, the "M" labels are hard to read. Since we don't define them or
>use them later, perhaps we can just remove all of the "M" labels. The "P"
>labels are OK; people will assume they are processes.
>- On slide 64 (The ITAPS data model abstracts...), the animation covers the
>text in the PDF version, and it is covering key definitions. Since we have
>to submit PDF, perhaps we should have one slide without the animation and
>one with it, so the definitions appear in the PDF.
>- On slide 65 (The ITAPS data model has four...), there is one of those odd
>carriage return characters at the end of the "Entity" bullet.
>- In the example on slide 115 (Ghost entities), we use ITAPS terminology in
>a natural but technically incorrect way. Our example is 2D, so the
>ghost-entity dim and bridge-entity dim are correct. But the text talks
>about regions being ghosted across faces. In ITAPS terminology, we are
>really ghosting faces across edges. But it sounds odd to call 2D finite
>elements "faces." And a 3D example would look too complicated. Probably
>the best solution is to describe the example as "one layer of ghost
>triangles for all boundary triangles sharing edges."
>Thanks again!
>Karen
More information about the itaps-parallel
