itaps-parallel inconsistencies in getAllVtxCoords
Jason Kraftcheck
kraftche at cae.wisc.edu
Sun Sep 14 21:11:21 CDT 2008
Carl Ollivier-Gooch wrote:
> Onkar Sahni wrote:
>> Or in case of mesh over 3D-surface curve.
>> - Onkar
>>> Lori,
>>> I would say num_vtx*3 as 2D meshes can be non-aligned with x-, y- and z-
>>> axes resulting in non-constant value for the 3rd dim. (which is not
>>> considered in case of num_vtx*num_dim when num_dim=2).
> I'd argue that in these cases, num_dim should be 3, not 2. After all,
> the call is getGeometricDimension, not getTopologicalDimension... :-)
I agree. If the implementation (e.g. MOAB) doesn't support
geometrically 2D meshes then it should always return 3 from
getGeometricDimension. If there is a need to check the topological
dimension of a mesh, the application should just ask for the number of
regions in the mesh.
- jason
More information about the itaps-parallel
