itaps-parallel inconsistencies in getAllVtxCoords
Tim Tautges
tautges at mcs.anl.gov
Fri Sep 12 20:18:37 CDT 2008
I'd rather we returned 3*num_vtx, that way apps don't need to call
num_dimensions and branch on that. But, I do 3d for everything. Come
to think of it, why is it we need to prescribe what is returned?
There's a size returned for that coordinate array, isn't there? Then
the number of dims is coords_size/num_vtx.
- tim
Lori A. Diachin wrote:
> Hi Carl and Tim,
> Right after you left today a question came up regarding what functions
> such as getAllVtxCoords should return for 2D meshes. In my and Ting's
> implementations, we return an array of num_vtx*num_dim but you and Tim
> seem to return num_vtx*3 regardless of the dimension of the mesh. The
> documentation doesn't specify the proper behavior.
> Thoughts?
> Lori
steadfast, because he trusts in you." Isaiah 26:3
Tim Tautges Argonne National Laboratory
(tautges at mcs.anl.gov) (telecommuting from UW-Madison)
phone: (608) 263-8485 1500 Engineering Dr.
fax: (608) 263-4499 Madison, WI 53706
More information about the itaps-parallel
