itaps-parallel inconsistencies in getAllVtxCoords
Onkar Sahni
osahni at scorec.rpi.edu
Fri Sep 12 18:29:31 CDT 2008
Or in case of mesh over 3D-surface curve.
- Onkar
> Lori,
> I would say num_vtx*3 as 2D meshes can be non-aligned with x-, y- and z-
> axes resulting in non-constant value for the 3rd dim. (which is not
> considered in case of num_vtx*num_dim when num_dim=2).
> - Onkar
>> Hi Carl and Tim,
>> Right after you left today a question came up regarding what functions
>> such
>> as getAllVtxCoords should return for 2D meshes. In my and Ting's
>> implementations, we return an array of num_vtx*num_dim but you and Tim
>> seem
>> to return num_vtx*3 regardless of the dimension of the mesh. The
>> documentation doesn't specify the proper behavior.
>> Thoughts?
>> Lori
More information about the itaps-parallel
