itaps-parallel inconsistencies in getAllVtxCoords
Onkar Sahni osahni at scorec.rpi.edu
Fri Sep 12 18:27:46 CDT 2008
Lori,
I would say num_vtx*3 as 2D meshes can be non-aligned with x-, y- and z-
axes resulting in non-constant value for the 3rd dim. (which is not
considered in case of num_vtx*num_dim when num_dim=2).
- Onkar
> Hi Carl and Tim,
> Right after you left today a question came up regarding what functions
> such
> as getAllVtxCoords should return for 2D meshes.   In my and Ting's
> implementations, we return an array of num_vtx*num_dim but you and Tim
> seem
> to return num_vtx*3 regardless of the dimension of the mesh.  The
> documentation doesn't specify the proper behavior.
> Thoughts?
> Lori
More information about the itaps-parallel mailing list
