itaps-parallel /usr/local/itaps on mesh.ep.wisc.edu
Mark Miller miller86 at llnl.gov
Thu Sep 11 11:59:14 CDT 2008
Hi All,
   Ok, I've installed plugins for MOAB and GRUMMP implementations to
the currently installed VisIt in /usr/local/itaps and confirmed they
work on test data. The GRUMMP plugin works only on volume mesh files. I
don't know why yet but it does not work on surface mesh (.smesh) or
boundary (.bdry) files for GRUMMP. These plugins are named 'ITAPS_MOAB'
and 'ITAPS_GRUMMP'.
   I tried building the FMDB installation I have installed locally at
LLNL, fmdb_rev2272.tar.gz, on mesh.ep.wisc.edu. I ran into problems that
I think are related to gcc-4.3 compatibility so I did not persue
further. So, there is presently no FMDB plugin for VisIt.
On Thu, 2008-09-11 at 10:30 -0500, Tim Tautges wrote:
> Mark Miller wrote:
> > Hi All,
> > I've been working on getting VisIt RE-installed with support for all
> > three ITAPS implementations and have a hit a couple of snags...
> > 2. -fPIC not used to produce the .a's for MOAB. I need to build
> >    .so's for VisIt. To do this from .a's for MOAB, those .a's needed
> >    to have been compiled with position independent code (-fPIC).
> >    Alternatively, if .so's for MOAB are there, I can use those
> >    directly.
> Ok, I've modified the installed MOABser on mesh.ep to have both shared
> and static libs.  For parallel does it make sense to have shared libs?
> MOAB's make didn't work for parallel with shared libs, due to hdf5
> having unresolved externals.
> - tim
Mark C. Miller, Lawrence Livermore National Laboratory
email: mailto:miller86 at llnl.gov
(M/T/W) (925)-423-5901 (!!LLNL BUSINESS ONLY!!)
(Th/F)  (530)-753-8511 (!!LLNL BUSINESS ONLY!!)
More information about the itaps-parallel mailing list
