itaps-parallel /usr/local/itaps on mesh.ep.wisc.edu
Tim Tautges
tautges at mcs.anl.gov
Thu Sep 11 10:30:22 CDT 2008
Mark Miller wrote:
> Hi All,
> I've been working on getting VisIt RE-installed with support for all
> three ITAPS implementations and have a hit a couple of snags...
> 2. -fPIC not used to produce the .a's for MOAB. I need to build
> .so's for VisIt. To do this from .a's for MOAB, those .a's needed
> to have been compiled with position independent code (-fPIC).
> Alternatively, if .so's for MOAB are there, I can use those
> directly.
Ok, I've modified the installed MOABser on mesh.ep to have both shared
and static libs. For parallel does it make sense to have shared libs?
MOAB's make didn't work for parallel with shared libs, due to hdf5
having unresolved externals.
- tim
steadfast, because he trusts in you." Isaiah 26:3
Tim Tautges Argonne National Laboratory
(tautges at mcs.anl.gov) (telecommuting from UW-Madison)
phone: (608) 263-8485 1500 Engineering Dr.
fax: (608) 263-4499 Madison, WI 53706
More information about the itaps-parallel
