itaps-parallel /usr/local/itaps on mesh.ep.wisc.edu
Mark Miller miller86 at llnl.gov
Wed Sep 3 18:12:59 CDT 2008
Hi Vitas,
Yeah, I get same error with VisIt. If you follow the instructions in the
error message, it works pretty fine. Let me know if you don't get it to
go. I might be able to help.
On Wed, 2008-09-03 at 16:14 -0600, Vitus Leung wrote:
> Tim,
> I have "installed" ParMETIS3_1, Zoltan, and iZoltan.  When I tried to
> run moabzoltan using MOABser, I got the following error message.
> Vitus
> vjleung at mesh:/usr/local/itaps/iZoltan$ mpirun -np 2 ./moabzoltan 2
> ilcend.cub VERTEX tmp.vtk
> mpiexec_mesh: cannot connect to local mpd (/tmp/mpd2.console_vjleung);
> possible causes:
>   1. no mpd is running on this host
>   2. an mpd is running but was started without a "console" (-n option)
> In case 1, you can start an mpd on this host with:
>     mpd &
> and you will be able to run jobs just on this host.
> For more details on starting mpds on a set of hosts, see
> the MPICH2 Installation Guide.
> On Wed, 2008-09-03 at 11:42 -0600, Tim Tautges wrote:
> > Hi all,
> >    For those of you with access to mesh.ep.wisc.edu, I've made a
> > /usr/local/itaps directory, and an itaps group, and made you all members
> > of that group.  You're welcome to install tools into that directory that
> > might be useful to others.  At a minimum, I think any of the tools we
> > give examples of in the tutorials should be there, including MOAB, FMDB,
> > visit, Mesquite, and maybe Frontier.  I've installed MOABser and MOABpar
> > there already (serial and parallel versions, resp.).
> > - tim
> > "You will keep in perfect peace him whose mind is
> >    steadfast, because he trusts in you."               Isaiah 26:3
> >               Tim Tautges            Argonne National Laboratory
> >           (tautges at mcs.anl.gov)      (telecommuting from UW-Madison)
> >           phone: (608) 263-8485      1500 Engineering Dr.
> >             fax: (608) 263-4499      Madison, WI 53706
Mark C. Miller, Lawrence Livermore National Laboratory
email: mailto:miller86 at llnl.gov
(M/T/W) (925)-423-5901 (!!LLNL BUSINESS ONLY!!)
(Th/F)  (530)-753-8511 (!!LLNL BUSINESS ONLY!!)
More information about the itaps-parallel mailing list
