itaps-parallel /usr/local/itaps on mesh.ep.wisc.edu
Vitus Leung vjleung at sandia.gov
Wed Sep 3 17:14:26 CDT 2008
Tim,
I have "installed" ParMETIS3_1, Zoltan, and iZoltan.  When I tried to
run moabzoltan using MOABser, I got the following error message.
Vitus
vjleung at mesh:/usr/local/itaps/iZoltan$ mpirun -np 2 ./moabzoltan 2
ilcend.cub VERTEX tmp.vtk
mpiexec_mesh: cannot connect to local mpd (/tmp/mpd2.console_vjleung);
possible causes:
  1. no mpd is running on this host
  2. an mpd is running but was started without a "console" (-n option)
In case 1, you can start an mpd on this host with:
    mpd &
and you will be able to run jobs just on this host.
For more details on starting mpds on a set of hosts, see
the MPICH2 Installation Guide.
On Wed, 2008-09-03 at 11:42 -0600, Tim Tautges wrote:
> Hi all,
>    For those of you with access to mesh.ep.wisc.edu, I've made a
> /usr/local/itaps directory, and an itaps group, and made you all members
> of that group.  You're welcome to install tools into that directory that
> might be useful to others.  At a minimum, I think any of the tools we
> give examples of in the tutorials should be there, including MOAB, FMDB,
> visit, Mesquite, and maybe Frontier.  I've installed MOABser and MOABpar
> there already (serial and parallel versions, resp.).
> - tim
> "You will keep in perfect peace him whose mind is
>    steadfast, because he trusts in you."               Isaiah 26:3
>               Tim Tautges            Argonne National Laboratory
>           (tautges at mcs.anl.gov)      (telecommuting from UW-Madison)
>           phone: (608) 263-8485      1500 Engineering Dr.
>             fax: (608) 263-4499      Madison, WI 53706
More information about the itaps-parallel mailing list
