itaps-parallel pdf of tutorial slides draft
Lori A. Diachin diachin2 at llnl.gov
Wed Sep 3 12:12:46 CDT 2008
Hi all,
Here is a very rough draft of the tutorial slides (pdf format).  All
I've been been able to do so far is rearrange the slides from the
SciDAC07 tutorial and incorporate Karen's slides into the appropriate
slot.  There is still much work to be done, but I wanted to send this
out before our discussion today.
I'm still having trouble checking into the svn repository (although I
can check out with no problem).  If someone can accept a 24M email and
check it in, I'll send them the ppt slides (rather than sending to the
entire list).
Lori
Type: application/pdf
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/itaps-parallel/attachments/20080903/5c5894b1/attachment.pdf>
More information about the itaps-parallel mailing list
