itaps-parallel Estimated implementation levels on ITAPS parallel interface routines
Tim Tautges
tautges at mcs.anl.gov
Tue Jun 10 11:24:28 CDT 2008
txie at scorec.rpi.edu wrote:
> Hi, All,
> The attached is our reviews on the ITAPS parallel interface routines to
> indicate the estimated implementation levels to support parallel mesh
> adaptivity, including easy, intermediate and hard. The routines we do not
> consider now are also listed in the file.
> In the review, we also found two possible problems as follows:
> 1. Type definitions are needed for iMeshP_PartitionHandle,
> iMeshP_PartHandle, iMeshP_RequestHandle, iMeshP_Status and etc, just as
> what we defined in iBase.h before.
- IMO, the part/partition handle types should be identical to
entitysethandle types (not typedef'd to the iMesh types, but whatever
those are typedef'd to, probably void*?
- RequestHandle, StatusHandle should be typedef'd to the equivalent MPI
entities, IMO.
> 2. To support the parallel mesh adaptivity, maybe the Parallel File I/O
> routines are missing to load/write-out partitioned mesh.
I thought we were going to handle that through the options to iMesh_load
(that's the way I've been doing it in MOAB, anyway).
- tim
> Please let us know if you have any problems about the attached file.
> Thanks,
> Ting
steadfast, because he trusts in you." Isaiah 26:3
Tim Tautges Argonne National Laboratory
(tautges at mcs.anl.gov) (telecommuting from UW-Madison)
phone: (608) 263-8485 1500 Engineering Dr.
fax: (608) 263-4499 Madison, WI 53706
More information about the itaps-parallel
