itaps-parallel Estimated implementation levels on ITAPS parallel interface routines
txie at scorec.rpi.edu
Tue Jun 10 08:04:01 CDT 2008
Hi, All,
The attached is our reviews on the ITAPS parallel interface routines to
indicate the estimated implementation levels to support parallel mesh
adaptivity, including easy, intermediate and hard. The routines we do not
consider now are also listed in the file.
In the review, we also found two possible problems as follows:
1. Type definitions are needed for iMeshP_PartitionHandle,
iMeshP_PartHandle, iMeshP_RequestHandle, iMeshP_Status and etc, just as
what we defined in iBase.h before.
2. To support the parallel mesh adaptivity, maybe the Parallel File I/O
routines are missing to load/write-out partitioned mesh.
Please let us know if you have any problems about the attached file.
Ting
Type: text/x-chdr
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/itaps-parallel/attachments/20080610/366b72b1/attachment.h>
More information about the itaps-parallel
