itaps-parallel Assignments for parallel interface, due before 2/5 phone conf
Vitus Leung
vjleung at sandia.gov
Tue Feb 5 13:15:45 CST 2008
On Tue, 2008-02-05 at 10:45 -0700, Devine, Karen D wrote:
> Vitus: Thanks for the corrections and sorry for the confusion. I think
> these calls need some sort of "message tag" (analogous to MPI's message tag)
> that allows sends and receives to be interwoven. Also, we should consider
> whether we need a post/send/wait model as Onkar described.
> Karen
Actually, no confusion. Good suggestion o the "message tag" that would
allow sends and receives to be interwoven and better support the
post/send/wait model that Onkar suggested. Also, good suggestions from
Onkar on ghosts and Par in name. However, I still think that the two
calls are sufficient.
void prefix_sendEntArrToPartsPar(iMesh_Instance instance,
/*in*/ const prefix_PartitionHandle partition_handle,
/*in*/ const iBase_EntityHandle *entity_handles,
/*in*/ const int entity_handles_size,
/*in*/ const int *target_part_ids,
/*in*/ int command_code, // e.g., MIGRATE,COPY
/*in*/ int update_ghost, // e.g., YES,NO
/*in*/ int message_tag,
int *err);
// The implementation has everything it needs to determine sends and
// receives. It can send and post non-blocking receives. Upon return,
// the application can do other stuff for latency hiding.
void prefix_receiveEntArrToPartsPar(iMesh_Instance instance,
/*inout*/ iBase_EntityHandle **entity_handles,
/*inout*/ int *entity_handles_size,
/*out*/ int *entity_handles_allocated,
/*inout*/ int *target_part_ids,
/*out*/ int *target_part_ids_allocated,
/*inout*/ int command_code, // e.g., MIGRATE,COPY
int *err);
// The implementation can post blocking receives or wait for non-
// blocking receives previously posted. Targets are correct, because
// there may be multiple parts on a processor and the application does
// not need to know sources. The message_tag ties
// a send and receive pair together.
Vitus
More information about the itaps-parallel
