itaps-parallel Assignments for parallel interface, due before 2/5 phone conf
Devine, Karen D
kddevin at sandia.gov
Tue Feb 5 11:45:21 CST 2008
Vitus: Thanks for the corrections and sorry for the confusion. I think
these calls need some sort of "message tag" (analogous to MPI's message tag)
that allows sends and receives to be interwoven. Also, we should consider
whether we need a post/send/wait model as Onkar described.
Karen
On 2/4/08 1:30 PM, "Vitus Leung" <vjleung at sandia.gov> wrote:
> On Tue, 2008-01-22 at 11:48 -0700, Devine, Karen D wrote:
>> Vitus:
>> - Propose the communication functions needed to support
>> prefix_sendEntArrToParts and prefix_receiveEntArrToParts.
> Karen,
> Here are the minor syntax corrections we discussed for these two
> functions.
> void prefix_sendEntArrToParts(iMesh_Instance instance,
> /*in*/ const prefix_PartitionHandle
> partition_handle,
> /*in*/ const iBase_EntityHandle *entity_handles,
> /*in*/ const int entity_handles_size,
> /*in*/ const int *target_part_ids,
> /*in*/ int command_code, // e.g., MIGRATE,COPY
> int *err);
> void prefix_receiveEntArrToParts(iMesh_Instance instance,
> partition_handle,
> /*inout*/ iBase_EntityHandle **entity_handles,
> /*inout*/ int *entity_handles_size,
> /*out*/ int *entity_handles_allocated,
> /*inout*/ int *target_part_ids,
> /*out*/ int *target_part_ids_allocated,
> /*inout*/ int command_code, // e.g., MIGRATE,COPY
> int *err);
> The prefix_sendEntArrToParts() should be a collective call. With the
> entity_handles and target_part_ids in all the calls, the implementation
> can determine the pairwise send/receives with all to all communication.
> This can be held by the implementation until the
> prefix_receiveEntArrToParts() call or passed back to the application in
> an additional argument. If the additional argument is used, it should
> be passed to prefix_receiveEntArrToParts().
> Vitus
More information about the itaps-parallel
