itaps-parallel mesh adaptivity example for SC08
Onkar Sahni
osahni at scorec.rpi.edu
Wed Nov 12 23:36:15 CST 2008
> While you won't be talking about main.cc, I do think it's a useful file
> for students to look at (I found it useful at any rate). It follows the
> skeleton you describe in the notes, and as I said, it uses many of the
> functions the students will already know and be comfortable with, so it
> provides useful reinforcement of those ideas. I would like to find some
> way to highlight the main function - even if you don't move the file,
> can you move the main function up to the beginning of the file and point
> to it in your session notes?
I have modified main.cc to contain only main() function. Also see
updated HandsOn_Session.txt. Let me know if I missed something...
Onkar
> Lori
> Onkar Sahni wrote:
>> Lori,
>> I appreciate your efforts in looking into mesh-adaptivity example and
>> providing detailed feedback. See my comments below majority of which are
>> fixes (my comments are inlined and starts with **, it seems like my
>> email
>> client has jumbled some text from your message while replying to it):
>>> - can you move the note/iMeshMA.README.SC08 up one level and rename it
>>> HandsOn_Session.txt to be consistent with the other exercises
>> ** Fixed, see HowTo.txt and HandsOn_Session.txt under:
>> /usr/local/itaps/mesh_refinement/
>>> - can you move the main.cc file and main Makefile up as well? In
>>> addition, I think it would be good if you could list the main function
>> as the first (and maybe only) thing in the file. By the time the
>> students get to this point they will recognize many of the operations
>> and functions that you use there, which will help them get comfortable
>> with this example.
>> ** This will be difficult for me as it will require (non-trivial)
>> changes
>> in Makefile and (iMeshMA's) svn repository structure. I do not plan to
>> talk about main.cc at all. I will just focus on three iMeshP calls as
>> mentioned in HandsOn_Session_iMeshMA.txt.
>>> - I find the text description in the notes to be a little sparse. I
>>> was able to follow the directions and run all the test cases, so that
>> was good. (As a general comment, we should remind folks how to set the
>> display for visualization of results.) You talk about specific iMeshP
>> functions that you focus on, but there's nothing really to do except go
>> look at the function (also the first one has a typo - should be
>>> pushTagsEnt). Can you tell me what you have in mind?
>> ** I plan to go through the code and show how three specific iMeshP
>> calls
>> are used. I plan to spent some time in description and discussions
>> related
>> to these three iMeshP calls.
>>> - I like the description of the overall skeleton of the mesh adapt
>>> service, but think that might be better earlier in this file (before
>>> the
>> description of the particular iMeshP functions). I'm not sure I see a
>> need for ~~ vs ~... I'd just list all the steps as equals
>> ** Fixed.
>>> - I don't understand the notation for detailed iMeshP function
>>> listings.. what's the difference between +++, single quotes, and ===
>> also, you use a lot of iMesh functions as well, but don't mention
>> them... why not? As a minor comment, the caps/lowercase letters aren't
>> consistent with the header files.
>> ** Fixed (I want to keep focus on iMeshP for various reasons).
>>> - It would be useful to explicitly say what you want the students to
>>> get out of this exercise. Are there things they should particularly be
>> looking for in the functions you highlight.. are you hoping they'll get
>> a sense of how to write/use a mesh adapt service?
>> ** This can cover many things, for example, basic understanding of three
>> iMeshP calls, a basic demonstration of interoperability, promotion of a
>> mesh-adapt service from ITAPS to scientific computing app. and showing a
>> mesh modification app. how iMeshP fulfills it needs for parallel mesh
>> adaptivity... we can discuss more on this tomorrow during our tele-con.
>> I am planning to talk/discuss during mesh adaptivity example that will
>> allow me to describe things. This is the reason why I wanted to get an
>> idea on time distribution for each hands-on session that will help me to
>> plan my discussions.
>> If I missed on any of your concerns/comments then please let me know.
>> Thanks,
>> Onkar
>>> Perhaps we can talk about this more tomorrow during the telecon...
>>> Lori
>>> Onkar Sahni wrote:
>>>> I have updated mesh adaptivity example (based on useful feedback from
>>>> you
>>>> guys and updates to database libraries) under:
>>>> (see /usr/local/itaps/mesh_refinement/notes/iMeshMA.README.SC08 to
>> compile, to run and for other details).
>>>> Please feel free to try it out and let me know your comments.
>>>> Thanks,
>>>> Onkar
>>>>> I have setup mesh adaptivity example under:
>>>>> See /usr/local/itaps/mesh_refinement/notes/iMeshMA.README.SC08 to
>>>> compile
>>>>> and run (and other details).
>>>>> Source code (clean version) is under:
>>>>> /usr/local/itaps/mesh_refinement/src
>>>>> A build is provided under:
>>>>> /usr/local/itaps/mesh_refinement/build
>>>>> Please try it out and let me know your comments.
>>>>> Thanks,
>>>>> Onkar
More information about the itaps-parallel
