itaps-parallel Notes from tutorial exercises
Devine, Karen D
kddevin at sandia.gov
Tue Nov 11 14:24:47 CST 2008
Tim:
Do you have time to build and run your example programs (FindAdj, List&Sets,
etc.) that are in the tutorial slides? In response to Lori's question, I
tried to build the F77 FindAdjacency example, but I didn't succeed. I
couldn't find F77 include files in FMDB. I tried using MOAB, but cray
pointers in the example appear to be 32-bit while the MOAB libraries that
are installed are 64-bit. I don't know enough about cray pointers and
fortran to resolve the problem. Even if I had gotten everything compiled, I
didn't have an appropriate input file for testing.
It would be a good sanity test for us to make sure our examples in the
slides compile and run correctly. We could have a separate directory for
them in /usr/local/itaps.
If I had a working example to use, I think I could convert hello_iMeshP.c to
hello_iMeshP.F.
Also, the FindAdj example in the slides has the root_set == 0 assumption in
at least the C and F77 versions.
Thanks!
Karen
On 11/11/08 11:02 AM, "Lori A. Diachin" <diachin2 at llnl.gov> wrote:
> Hi Vitus and all,
> I went through both tutorials this morning and overall think they're
> quite nice. I like that you provide the basics here in the second
> exercise - it's a very nice bridge between Hello and Smooth. I have a
> few minor notes (below).
> As a general comment to everyone - do we have any tutorial exercises
> that aren't in C++? I've gone through Hello, Load Balance and Smooth so
> far and I'm worried we'll give folks the wrong impression.. I see a .c
> file in the Hello directory -- would it be hard to add a fortran hello
> example?
> Lori
> Tutorial 1:
> Exercise 2: It's not clear to me where the MPI communicator is
> initialized in the test file? I assume it's COMM_WORLD, but you refer
> to 'initialized above' and I don't see it. I assume it's in the Init
> function, but it might be helpful to make it more explicit
> Exercise 3: Remind users how to get a string length; not all users will
> be c++ savy.
> In general it's not always clear to me why I'm doing something, getting
> the parts, getting various handles, etc - is it needed for Zoltan? If
> you can, it would be useful to add a sentence to the beginning of each
> exercise giving a bit of motivation for why I need to call this
> function. It will help folks think through it themselves later..
> Tutorial 2:
> Might prefer to have different test file names in tutorial 1 and
> tutorial 2.... Actually, rather than switching files/directories, you
> could keep them all part of a single tutorial and just use the #define
> trick that Karen used in Hello.
> Is .vtu a vtk format? I'm not familiar with it and was surprised to see
> .vtu's... you might want to comment on what to expect in the notes for
> Exercise 1
More information about the itaps-parallel
