itaps-parallel New version of iMeshP.h committed
txie at scorec.rpi.edu
Fri Nov 7 13:46:25 CST 2008
Karen and Onkar,
Thanks for the discussion. I am sorry for this confusion. I will look into
the FMDB_iMeshP implementation and modify this function in "offset" way
very soon.
Ting
> My preference would be to stay closer to other iMesh functions where
> similar types of array exists (in concept)... I guess others (Carl,
> Tim...) can help me on this one...
> If we decide to go with the way FMDB does it (as of now) then I agree with
> Karen to change the name from "offset" to "numNewPerOld" or something...
> good catch Karen... now if I think about it I do not know why FMDB does it
> "numNewPerOld" way if the array is called offset... I will ask Ting to
> look into it...
> In summary, if others tell a solution (as per iMesh standards) in a day or
> two then we take that solution... otherwise I will say FMDB needs to be
> updated and use "offset" as offset not "numNewPerOld" because the
> documentation clearly explains offset... the only example getting affected
> by this (that I can think of) is mesh adaptivity which I can take care of.
> This issue I think we will clear before SC08 as I plan to talk about this
> function in tutorial.
> Thanks,
> Onkar
>> OK; I don't care which way we do it. If we do it your way, I will
>> change
>> the name of the variable from "offset" to "numNewPerOld" or something
>> like
>> that, since it is more of a count than an offset.
>> Let me know which approach you think is more natural. Then either I'll
>> change the documentation or you'll change your code.
>> Thanks for your reply.
>> Karen
>> On 11/6/08 7:20 PM, "Onkar Sahni" <osahni at scorec.rpi.edu> wrote:
>>> Karen,
>>> Thanks for the nice summary.
>>> See my response below (inlined) on two items.
>>>> - How is the offset array in iMeshP_replaceOnPartBdry used? I
>>>> guessed
>>>> the
>>>> following; Onkar, let me know if it is correct. If it is correct, do
>>>> we
>>> need offset_size?
>>>> offset (In) Index into new_entities; old_entities[i]
>>>> is replaced by new_entities[offset[i]] to
>>>> new_entities[offset[i+1]-1].
>>> As of now FMDB assumes that old_entities[i] has offset[i] "new ents",
>>> following snippet of code may help:
>>> int count = 0;
>>> for(int i=0; i<old_entities_size; i++) {
>>> for(int j=0; j<offset[i]; j++) {
>>> child[i] = new_entities[count+j];
>>> count += offset[i];
>>> But I do not see any problem to accomplish the same in the way you
>>> described it (and as it is in recent iMeshP.h). Ting can provide more
>>> details.
>>>> - Add functions to either pull or accumulate tag data as proposed by
>>> Jason.
>>> Karen, I see the status of iMeshP_pullTags{Ent} here. Sorry for
>>> sending
>>> you questions separately.
>>> Thanks,
>>> Onkar
More information about the itaps-parallel
