itaps-parallel New version of iMeshP.h committed
Onkar Sahni osahni at scorec.rpi.edu
Fri Nov 7 13:35:55 CST 2008
My preference would be to stay closer to other iMesh functions where
similar  types of array exists (in concept)... I guess others (Carl,
Tim...) can help me on this one...
If we decide to go with the way FMDB does it (as of now) then I agree with
Karen to change the name from "offset" to "numNewPerOld" or something...
good catch Karen... now if I think about it I do not know why FMDB does it
"numNewPerOld" way if the array is called offset... I will ask Ting to
look into it...
In summary, if others tell a solution (as per iMesh standards) in a day or
two then we take that solution... otherwise I will say FMDB needs to be
updated and use "offset" as offset not "numNewPerOld" because the
documentation clearly explains offset... the only example getting affected
by this (that I can think of) is mesh adaptivity which I can take care of.
This issue I think we will clear before SC08 as I plan to talk about this
function in tutorial.
Onkar
> OK; I don't care which way we do it.  If we do it your way, I will change
> the name of the variable from "offset" to "numNewPerOld" or something like
> that, since it is more of a count than an offset.
> Let me know which approach you think is more natural.  Then either I'll
> change the documentation or you'll change your code.
> Thanks for your reply.
> Karen
> On 11/6/08 7:20 PM, "Onkar Sahni" <osahni at scorec.rpi.edu> wrote:
>> Karen,
>> Thanks for the nice summary.
>> See my response below (inlined) on two items.
>>> -  How is the offset array in iMeshP_replaceOnPartBdry used?  I guessed
>>> the
>>> following; Onkar, let me know if it is correct.  If it is correct, do
>>> we
>> need offset_size?
>>>       offset  (In)  Index into new_entities; old_entities[i]
>>>                     is replaced by new_entities[offset[i]] to
>>>                     new_entities[offset[i+1]-1].
>>   As of now FMDB assumes that old_entities[i] has offset[i] "new ents",
>> following snippet of code may help:
>>   int count = 0;
>>   for(int i=0; i<old_entities_size; i++) {
>>     for(int j=0; j<offset[i]; j++) {
>>       child[i] = new_entities[count+j];
>>     count += offset[i];
>>   But I do not see any problem to accomplish the same in the way you
>> described it (and as it is in recent iMeshP.h). Ting can provide more
>> details.
>>> -  Add functions to either pull or accumulate tag data as proposed by
>> Jason.
>>    Karen, I see the status of iMeshP_pullTags{Ent} here. Sorry for
>> sending
>> you questions separately.
>> Thanks,
>> Onkar
More information about the itaps-parallel mailing list
