itaps-parallel Notes from today's telecon
Onkar Sahni osahni at scorec.rpi.edu
Thu Nov 6 13:59:56 CST 2008
Thanks Karen. I will incorporate the change in step (a) of compile.
For output on screen I do plan to clean it a bit. As usual, this first
phase was to get code ported/linked... and create README before today's
mirror deadline.
For viz., currently vtk files are written out and so next step (as of now)
is to viz. them and get a sense of what happened. I haven't planned any
exercises yet.
Onkar
> Hi, Onkar.  I tried the examples, and was able to build and execute with
> the
> following modification:
> In "to compile" section, step (a) should include "src" in DEVROOT:
>   export DEVROOT=$HOME/mesh_refinement/src
> The test program gives a lot of output; I think most of it is from
> iZoltan.
> I asked Vitus to turn the output level down in iZoltan, so his change will
> benefit you as well.  I'm not sure what the rest of the output means;
> perhaps you can make it less terse.  Also, for parallel output with
> statistics about data on an individual processor, can you include the
> processor number?
> Can the users visualize what happened with the program?
> Having built and run the program, I'm not sure what to do next.  Are you
> planning to have a presentation to go along with the program?  Or will
> there
> be exercises?
> Thanks.
> Karen
> On 11/6/08 7:57 AM, "Onkar Sahni" <osahni at scorec.rpi.edu> wrote:
>> I have setup mesh adaptivity example under:
>> /usr/local/itaps/mesh_refinement
>> See /usr/local/itaps/mesh_refinement/notes/iMeshMA.README.SC08 to
>> compile
>> and run (and other details).
>> Source code (clean version) is under:
>> /usr/local/itaps/mesh_refinement/src
>> A build is provided under:
>> /usr/local/itaps/mesh_refinement/build
>> Please try it out and let me know your comments.
>> Lori, Karen and Vitus, could you guys please look past "compile and run"
>> in the above mentioned README file, namely at the three specific iMeshP
>> functions that this example will focus on. I will try to plan how to
>> discuss on these iMeshP calls (specially for
>> iMeshP_exchEntArrToPartsAll()
>> as mesh adaptivity example used it when it was not using iZoltan but now
>> it uses iZoltan and iZoltan makes call to this routine so I will
>> co-ordinate with Vitus on how to discuss this call).
>> Thanks,
>> Onkar
>>> Timeline:
>>>   - Noon CST, Thursday Nov 6: Mirror of current /usr/local/itaps being
>>> installed on SC machine
>>>   - COB CST, Friday Nov 7: All examples should be ready for trial by
>>> fire including instructions
>>>   - 11 am PST, Wednesday, Nov 12: Telecon to iron out last minute
>>> details
>>>   - COB Friday, Nov 14 CST: usr/local/itaps on Mesh machine will be
>>> mirrored and taken to SC on CD
>>>  - Saturday, Nov 15, Tim will email the IP address and guest account
>>> information so that folks
>>>     can log in and try their tutorial examples on new machine
>>>  - Sunday, Nov 16, Tutorial
>>> TODO:
>>>  - Create tutorial exercises and examples from current example codes;
>>> install in /usr/local/itaps
>>>      - Adaptive mesh w/ FMDB iMeshP
>>>      - Frontier w/ iMesh
>>>  - Test all examples - guinea-pigging (all)
>>>  - Ensure a consistent look and feel to the examples
>>>      - create a single document with example instructions to hand out
>>>  - Update web pages
>>>      - Doxygen comments for iMeshP (lori and karen)
>>>      - include .doxy on web page
>>>      - fix the navigation bar (lori)
>>>  - Draft cautionary note for READMEs indicating close contact with
>>> implementors a very good idea
>>>  - Update the tutorial slides to reflect new function names in iMeshP
>>>  - Update tarballs of implementations including directions for build in
>>> README
>>>  - Ensure all implementations have a consistent use of iMesh-Defs.inc;
>>> should be in lib directory
>>>  - Change directory structure on mesh machine so all tutorial examples
>>> in a single location
>>>  - Test build process for implementations using the newly created
>>> READMEs
>>>  - update iMesh.h and iBase.h *after* the tutorial.  Deadline of Dec 17
>>> Anything I missed?
>>>     http://www.petsworld.co.uk/guinea-pigs.htm
>>> <http://www.google.com/imgres?imgurl=http://www.petsworld.co.uk/images/guinea
>>> -pig.jpg&imgrefurl=http://www.petsworld.co.uk/guinea-pigs.htm&h=386&w=338&sz=
>>> 18&tbnid=j_ojN5cOoncJ::&tbnh=123&tbnw=108&prev=/images%3Fq%3Dguinea%2Bpig&hl=
>>> en&usg=__FlIO52HLPRISRi4zHLfrcBtekcM=&sa=X&oi=image_result&resnum=1&ct=image&
>>> cd=1>
More information about the itaps-parallel mailing list
