itaps-parallel Notes from today's telecon
Devine, Karen D
kddevin at sandia.gov
Thu Nov 6 13:26:48 CST 2008
Hi, Onkar. I tried the examples, and was able to build and execute with the
following modification:
In "to compile" section, step (a) should include "src" in DEVROOT:
export DEVROOT=$HOME/mesh_refinement/src
The test program gives a lot of output; I think most of it is from iZoltan.
I asked Vitus to turn the output level down in iZoltan, so his change will
benefit you as well. I'm not sure what the rest of the output means;
perhaps you can make it less terse. Also, for parallel output with
statistics about data on an individual processor, can you include the
processor number?
Can the users visualize what happened with the program?
Having built and run the program, I'm not sure what to do next. Are you
planning to have a presentation to go along with the program? Or will there
be exercises?
Thanks.
Karen
On 11/6/08 7:57 AM, "Onkar Sahni" <osahni at scorec.rpi.edu> wrote:
> I have setup mesh adaptivity example under:
> /usr/local/itaps/mesh_refinement
> See /usr/local/itaps/mesh_refinement/notes/iMeshMA.README.SC08 to compile
> and run (and other details).
> Source code (clean version) is under:
> /usr/local/itaps/mesh_refinement/src
> A build is provided under:
> /usr/local/itaps/mesh_refinement/build
> Please try it out and let me know your comments.
> Lori, Karen and Vitus, could you guys please look past "compile and run"
> in the above mentioned README file, namely at the three specific iMeshP
> functions that this example will focus on. I will try to plan how to
> discuss on these iMeshP calls (specially for iMeshP_exchEntArrToPartsAll()
> as mesh adaptivity example used it when it was not using iZoltan but now
> it uses iZoltan and iZoltan makes call to this routine so I will
> co-ordinate with Vitus on how to discuss this call).
> Thanks,
> Onkar
>> Timeline:
>> - Noon CST, Thursday Nov 6: Mirror of current /usr/local/itaps being
>> installed on SC machine
>> - COB CST, Friday Nov 7: All examples should be ready for trial by
>> fire including instructions
>> - 11 am PST, Wednesday, Nov 12: Telecon to iron out last minute details
>> - COB Friday, Nov 14 CST: usr/local/itaps on Mesh machine will be
>> mirrored and taken to SC on CD
>> - Saturday, Nov 15, Tim will email the IP address and guest account
>> information so that folks
>> can log in and try their tutorial examples on new machine
>> - Sunday, Nov 16, Tutorial
>> TODO:
>> - Create tutorial exercises and examples from current example codes;
>> install in /usr/local/itaps
>> - Adaptive mesh w/ FMDB iMeshP
>> - Frontier w/ iMesh
>> - Test all examples - guinea-pigging (all)
>> - Ensure a consistent look and feel to the examples
>> - create a single document with example instructions to hand out
>> - Update web pages
>> - Doxygen comments for iMeshP (lori and karen)
>> - include .doxy on web page
>> - fix the navigation bar (lori)
>> - Draft cautionary note for READMEs indicating close contact with
>> implementors a very good idea
>> - Update the tutorial slides to reflect new function names in iMeshP
>> - Update tarballs of implementations including directions for build in
>> README
>> - Ensure all implementations have a consistent use of iMesh-Defs.inc;
>> should be in lib directory
>> - Change directory structure on mesh machine so all tutorial examples
>> in a single location
>> - Test build process for implementations using the newly created READMEs
>> - update iMesh.h and iBase.h *after* the tutorial. Deadline of Dec 17
>> Anything I missed?
>> http://www.petsworld.co.uk/guinea-pigs.htm
>> <http://www.google.com/imgres?imgurl=http://www.petsworld.co.uk/images/guinea
>> -pig.jpg&imgrefurl=http://www.petsworld.co.uk/guinea-pigs.htm&h=386&w=338&sz=
>> 18&tbnid=j_ojN5cOoncJ::&tbnh=123&tbnw=108&prev=/images%3Fq%3Dguinea%2Bpig&hl=
>> en&usg=__FlIO52HLPRISRi4zHLfrcBtekcM=&sa=X&oi=image_result&resnum=1&ct=image&
>> cd=1>
More information about the itaps-parallel
