itaps-parallel Hello_iMeshP hands-on tutorial ready for review
Devine, Karen D kddevin at sandia.gov
Tue Nov 4 19:49:06 CST 2008
Lori:  Thanks for trying the hands-on exercise.  I made the following changes:
-  changed setenv to export for bash.
-  added ./ to executables since . is not in default path.
I do not know what the Examples subdirectory is.  I have it, too, and I cannot delete it.
Tim, do you know what it is?
Karen
Sent: Tuesday, November 04, 2008 5:17 PM
To: Devine, Karen D
Cc: itaps-parallel at mcs.anl.gov
Subject: Re: itaps-parallel Hello_iMeshP hands-on tutorial ready for review
Hi Karen,
I tried the Hello example as a new user of the iMesh system (I actually
had not logged on before today, so I was a good test user..).  It looks
very promising and I like the text and description you wrote - others
should try to emulate it.
Unfortunately, my environment (and I assume other new user environments)
did not allow me to get past the set up phase.   Here are the issues I
encountered:
1. What is in the Examples subdirectory? Do we need this?  Doesn't look
related to iMesh in any way.
2. default shell is bash, so setenv doesn't work (switched to tcsh)
3. hello_iMesh is not in the default path... needs to be ./hello_iMesh
4. error with running the parallel example - both tcsh and bash:  It
can't find the executable; so I assume I have to do something with
paths, but I'm not sure what....
mesh:~/Hello> mpirun -np 1 hello_iMeshP test_meshes/cube.1part/cube.sms
problem with execution of hello_iMeshP  on  mesh:  [Errno 2] No such
file or directory
mpirun -np 1 /mnt/disk2a/Hello/hello_iMeshP test_meshes/cube.1part/cube.sms
problem with execution of /mnt/disk2a/Hello/hello_iMeshP  on  mesh:
[Errno 2] No such file or directory
Do you want to make the appropriate changes to directions and I can try
again?
Lori
Devine, Karen D wrote:
> I have completed the hello_iMesh and hello_iMeshP hands-on exercise that
> will be used at the end of the tutorial's morning session.  Anyone who is
> interested (and, in particular, our guinea pigs) should feel free to review
> it.
> Step-by-step instructions for the tutorial are in
> /usr/local/itaps/Hello/HandsOn_Session1.txt.
> This hands-on session covers the following topics:
> -  Basic set-up for working on the mesh machine.
> -  Differences between hello_iMesh.c and hello_iMeshP.c
> -  Working with parts and part handles.
> -  Getting neighbor-part info.
> -  Getting vertices from a part.
> -  Getting coordinates for vertices.
> Please let me know what improvements can be made.
> Karen
More information about the itaps-parallel mailing list
