itaps-parallel Diagram of set-based parallel data
Onkar Sahni osahni at scorec.rpi.edu
Tue Dec 18 18:07:52 CST 2007
> I'll make a diagram equivalent to Carl's today, maybe that will make
> things a bit clearer.
> - tim
Maybe I am missing something, Carl's diagram had more than one part on
each process and there was an entity-set spanning multiple parts including
ones local to a process. And again, if I rightly understood the question
in discussion then how would one deal with a specific-part (doesn't matter
whether part is entity-set or not) and a specific-entity-set (spanning
more then one part local on a process).
- Onkar
> Hi all,
>    As promised, attached is a cartoon describing set-based parallel
> data.  Note I've stuck to the simplest example (as wisely advocated by
> Mark S).  I show the representation of the same mesh in the serial and
> 3-processor cases.  I don't show ghosted elements, for simplicity,
> though those "fit" in the model.
> PARALLEL
> In the parallel representation, each processor has a set it understands
> as "partition1" (labeled "Partn1").  In this example, on each processor,
> that set contains one set corresponding to the part assigned to that
> processor.  The part set contains 3d entities assigned to that
> processor.  In this example, all 3d entities are objects in the
> decomposition, therefore each 3d entity is a member of exactly one Part.
> There are other entity sets defined in this mesh, including a boundary
> condition set (BC1), material sets (Matl1, Matl2), and
> application-defined sets (App1-App3).  In this example, the BC1 set
> contains faces in the mesh (2d elements), but not all of them.  Matl1
> and Matl2 are meant to form a covering over 3d elements, defining the
> materials for those elements.  Application-defined sets are for
> arbitrary groupings.  Whether such "shared" sets would exist on
> processors even if there were no set contents on those processors is
> currently implementation-defined, though maybe there should be a common
> convention for that.
> Some of the sets on each processor are implicitly linked with sets on
> other processors.  For example, the Partn1 set on each processor is
> linked to the corresponding sets on other procs.  For this set, that
> means that if the mesh were ever to be assembled in a single file, the
> contents of Partn1 on various processors would all go into a single set,
> which would be assigned the union of all tags on that set on all
> processors.  Presumably those tags would all be the same.  Similarly,
> BC1 and Matl1, Matl2 are sets that are implicitly linked and which would
> be combined.  App1-App3 are application-defined sets which would be
> considered separate, even if the mesh was written to a single file.
> Note that the decision or designation of which sets across the
> processors are really the same sets is application- or
> implementation-defined.  In MOAB, we do it based on tag and optionally
> tag value.  So, for example, any set with a "MATERIAL_SET" tag whose
> value is the same is understood to be the same set.  This is used in the
> HDF5-based file writer in MOAB, which writes a single file in parallel
> from all processors.
> SERIAL
> In the serial case, all sets having implicitly-defined counterparts on
> other processors have been combined.  Thus, part sets (Part1-Part3) are
> contained in the Partn1 set, and there are single BC1, Matl1 and Matl2
> sets.  App1-App3 are still separate, since they were not designated to
> be the same sets.  The Part1-Part3 sets and Matl1-Matl2 sets are
> different coverings of all 3d entities in this mesh for this example.
> The BC1 set includes a subset of 2d entities in the mesh.
> DISCUSSION
> As I've mentioned before, I've implemented MOAB's parallel reader such
> that any collection of sets which forms a covering over the things I
> want to partition can be used to define the partition.  Thus, in this
> example, one could use Matl1/Matl2 as the part sets.  In this case,
> those sets would serve multiple purposes.  Similarly, I don't see any
> reason we shouldn't allow a given part set to be a member of multiple
> partitions.
> Part sets should also be allowed to include sets; in this case, maybe
> the sets are the objects in the partition.  This would be a very nice
> thing to use for e.g. hypergraph partitioning methods.
> Counter-intuitively, I would lean toward using contains relations to go
> down that hypergraph hierarchy.  If a given implementation did not
> implement Parts as legitimate entity sets, then this property could be
> used to reduce bookkeeping for adaptive applications, e.g. have the part
> contain sets which themselves contain 3d elements of a given material or
> geometric volume.  Of course, that assumes you're using sets for those
> other things...
> This method for representing partitions also has the following benefits:
> - allows multiple partitions to exist in the same file/instance/database
> - would allow current set operations to be used to query contents of
> parts and partitions
> - parallel view is only different when asking about parallel data; in
> other cases it looks the same as serial interface
> - other parts of RPI partition model can be embedded similarly, by using
> sets related to part sets using parent/child relations
> I'll be elaborating on this at the SIAM mtg in March, as well as pulling
> in other examples where sets can be used to do various things.  I guess
> that means I've already started my talk, which has to be some sort of
> record for me!
> Comments welcome, fire when ready!
> - tim
> "You will keep in perfect peace him whose mind is
>    steadfast, because he trusts in you."               Isaiah 26:3
>               Tim Tautges            Argonne National Laboratory
>           (tautges at mcs.anl.gov)      (telecommuting from UW-Madison)
>           phone: (608) 263-8485      1500 Engineering Dr.
>             fax: (608) 263-4499      Madison, WI 53706
More information about the itaps-parallel mailing list
