itaps-parallel Proposal for handling queries with parts, sets, and partitions
Tim Tautges
tautges at mcs.anl.gov
Tue Dec 18 16:58:33 CST 2007
Then why do we need functions operating on parts or partitions at all?
Those are reverse classification-type queries, right?
- tim
Mark Shephard wrote:
> Since the first thing that was agreed to is that there would be the
> ability to deal parts that does not require an implementation to do
> things via sets (reverse classification), I sure hope we are not getting
> this issue confused again. As discussed in some technical detail at the
> boot camp, there are two high level approaches one based on
> classification (no use of sets) and reverse classification (what sets do
> well). All the SCOREC tools that are being used for parallel adaptive
> simulations, and (in the past) for parallel mesh generation, are based
> on a classification approach.
> Onkar Sahni wrote:
>>> So again, I go back to asking: what are the core needs that prevent us
>>> from using sets as both parts and partitions? The entity set mechanism
>>> was designed with this specific usage in mind.
>> If "sets as both parts and partitions" mean using entity-sets then we
>> have
>> already discussed this in great detail. I think the question in
>> discussion
>> is irrespective of how one implements parts and partitions? If I
>> understood the question right then we need to answer queries which
>> involve
>> a specific part and a specific entity-set (where entity-set may span more
>> than one part, may be local to a process). Now, if it is implied that
>> choosing entity-sets for both parts and partitions allows to use set
>> operations (booleans), outside the interface explicitly by applications,
>> to answer such queries well then applications might as well do it in
>> other
>> equivalent ways (for example, loop over entities in set and ask residence
>> parts to get entities in the entity-sey belonging to a specific part).
>> - Onkar
steadfast, because he trusts in you." Isaiah 26:3
Tim Tautges Argonne National Laboratory
(tautges at mcs.anl.gov) (telecommuting from UW-Madison)
phone: (608) 263-8485 1500 Engineering Dr.
fax: (608) 263-4499 Madison, WI 53706
More information about the itaps-parallel
