itaps-parallel Proposal for handling queries with parts, sets, and partitions
Mark Shephard
shephard at scorec.rpi.edu
Tue Dec 18 16:48:35 CST 2007
Since the first thing that was agreed to is that there would be the
ability to deal parts that does not require an implementation to do
things via sets (reverse classification), I sure hope we are not getting
this issue confused again. As discussed in some technical detail at the
boot camp, there are two high level approaches one based on
classification (no use of sets) and reverse classification (what sets do
well). All the SCOREC tools that are being used for parallel adaptive
simulations, and (in the past) for parallel mesh generation, are based
on a classification approach.
Onkar Sahni wrote:
>> So again, I go back to asking: what are the core needs that prevent us
>> from using sets as both parts and partitions? The entity set mechanism
>> was designed with this specific usage in mind.
> If "sets as both parts and partitions" mean using entity-sets then we have
> already discussed this in great detail. I think the question in discussion
> is irrespective of how one implements parts and partitions? If I
> understood the question right then we need to answer queries which involve
> a specific part and a specific entity-set (where entity-set may span more
> than one part, may be local to a process). Now, if it is implied that
> choosing entity-sets for both parts and partitions allows to use set
> operations (booleans), outside the interface explicitly by applications,
> to answer such queries well then applications might as well do it in other
> equivalent ways (for example, loop over entities in set and ask residence
> parts to get entities in the entity-sey belonging to a specific part).
> - Onkar
More information about the itaps-parallel
