itaps-parallel Web archives up
Tim Tautges tautges at mcs.anl.gov
Fri Oct 26 11:37:48 CDT 2007
Thanks, I'll check with the systems people and make sure it's visible
from the outside.
- tim
txie at scorec.rpi.edu wrote:
> Tim,
> I tried now and can not access the website. The error information is
> listed below.
> Most likely, you reached this file by trying to access a URL like
>     http://www.mcs.anl.gov/subsite/directory/
> where "directory" does not have a default file specified. For security
> reasons, none of our web servers will return a list of all the files in
> the directory if a default file is not specified.
> Ting
>> Hi all,
>>    The web archives of this list are up, at
>> http://www-unix.mcs.anl.gov/web-mail-archive/lists/itaps-parallel/maillist.html.
>>   I'm at ANL right now, so haven't verified that it's accessible from
>> outside, but it should be.
>> - tim
>> "You will keep in perfect peace him whose mind is
>>   steadfast, because he trusts in you."               Isaiah 26:3
>>              Tim Tautges            Argonne National Laboratory
>>          (tautges at mcs.anl.gov)      (telecommuting from UW-Madison)
>>          phone: (608) 263-8485      1500 Engineering Dr.
>>            fax: (608) 263-4499      Madison, WI 53706
More information about the itaps-parallel mailing list
