itaps-parallel Web archives up
txie at scorec.rpi.edu txie at scorec.rpi.edu
Fri Oct 26 11:35:46 CDT 2007
Tim,
I tried now and can not access the website. The error information is
listed below.
Most likely, you reached this file by trying to access a URL like
    http://www.mcs.anl.gov/subsite/directory/
where "directory" does not have a default file specified. For security
reasons, none of our web servers will return a list of all the files in
the directory if a default file is not specified.
Ting
> Hi all,
>    The web archives of this list are up, at
> http://www-unix.mcs.anl.gov/web-mail-archive/lists/itaps-parallel/maillist.html.
>   I'm at ANL right now, so haven't verified that it's accessible from
> outside, but it should be.
> - tim
> "You will keep in perfect peace him whose mind is
>   steadfast, because he trusts in you."               Isaiah 26:3
>              Tim Tautges            Argonne National Laboratory
>          (tautges at mcs.anl.gov)      (telecommuting from UW-Madison)
>          phone: (608) 263-8485      1500 Engineering Dr.
>            fax: (608) 263-4499      Madison, WI 53706
More information about the itaps-parallel mailing list
