[hpc-announce] Call for Pre-proposals to host the IEEE Cluster 2029 Conference
Mohror, Kathryn mohror1 at llnl.gov
Fri May 15 10:30:32 CDT 2026
Dear Colleagues,
IEEE Cluster is a highly successful conference series that has been ongoing for more than 25 years.  With this email, we invite pre-proposals to host IEEE Cluster 2029.
As per IEEE Cluster's traditional US-Europe-US-Asia rotation, we anticipate selection of a bid from the US for Cluster 2029.  However, this rotation is not a strict requirement, so proposals from other locations will also be considered without any bias.  We are also interested in locations that do not fall under the traditional US-Europe-US-Asia model: Canada, Mexico, South America, Africa, Australia, and New Zealand.
Pre-proposals are simple two-slide decks.  The first slide introduces the location and the second slide introduces the key organizers (i.e., the General Chair(s) and the Program Chair(s)). For the selection process, the following are a subset of the steering committee's considerations:
    - Whether the location has been visited by IEEE Cluster in the recent past.  New locations are encouraged, although older locations will also be considered, if the conference was not held there recently.  The locations for the past editions of IEEE Cluster are available at https://urldefense.us/v3/__http://clustercomp.org/__;!!G_uCfscf7eWS!blaBzDdo085v_vT3RyoD2JR9aIqM4ZeHmZQx-HBYnBZqcWAehKxgMv9FJF2f8W9Z_tIBXS6jybz994rQurR2_ejM$
    - Whether the location is reasonably favorable for travel for a majority of our attendees.  Locations that have good flight connectivity and a good local presence of researchers working in the area of Cluster computing are better suited for the  conference.
    - Whether the key organizing committee (i.e., the General Chair(s) and Program Chair(s)) has experience with organizing conferences and in particular with IEEE Cluster.  If you have been involved with IEEE Cluster in the past (e.g., as an attendee, through publications, as a volunteer PC member or chair), the proposal would be given higher priority.
Pre-proposals are due on May 29, 2026, and notifications are expected to be sent out in late June. All pre-proposals should be sent to the steering committee chair, Kathryn Mohror (mohror1 at llnl.gov), for consideration.
The intent is to accept a single pre-proposal, which would then be invited to submit a full proposal (example pre-proposals and full proposals can be provided upon request).  However, the steering committee reserves the right to invite multiple pre-proposals to submit full proposals.
Full proposals must be presented at a steering committee meeting, after which a formal vote by the steering committee will decide if the proposal is accepted.
Thank you, and we look forward to your pre-proposals.
Kathryn Mohror
IEEE Cluster Steering Committee Chair
(on behalf of the IEEE Cluster Steering Committee)
More information about the hpc-announce mailing list
