[hpc-announce] Call for Papers -- Cluster 2023
Valero Lara, Pedro valerolarap at ornl.gov
Tue Feb 7 18:13:55 CST 2023
Please, consider to post the following CFP.
Thanks!
Pedro
https://clustercomp.org/2023/
IEEE Cluster 2023 is the 25th edition of the IEEE Cluster conference series. It is being held in cooperation with SIGHPC.
Clusters remain the primary system architecture for building many of today’s rapidly evolving computing infrastructures including high-performance computing, cloud computing and big data, and are used to solve some of the most complex problems. The challenges to make them scalable, efficient, productive, and increasingly effective requires a community effort in the areas of cluster system design, advancing the capabilities of the software stack, system management and monitoring, and the design of algorithms, methods, and applications to leverage the overall infrastructure
Following the successes of previous IEEE Cluster conferences, for IEEE Cluster 2023, which will be held Oct 31 - Nov 3, 2023 in Santa Fe, New Mexico, USA, we again solicit high-quality original work that advances the state-of-the-art in clusters and closely related fields.
All papers will be rigorously peer-reviewed for their originality, technical depth and correctness, potential impact, relevance to the conference, and quality of presentation. Research papers must clearly demonstrate novel research contributions while papers reporting experiences must clearly describe the lessons learned and the resulting impact, along with the utility of the approach in comparison to previous work.
Authors must indicate the primary topic area of their submissions from the four topic areas provided below. In addition, they may optionally rank their paper relative to the overall set of topics. The papers may be submitted as either a full 10-page paper or as a shorter 4-page paper submission. Please note that references are not counted in the limits on the number of pages and a 10-page submission may be accepted with a caveat of transforming it into a 4-page version for presentation at the conference.
IEEE Cluster 2023 will use a double-blind review process, which is a change from previous years. For an explanation of this process, please refer to the following link: https://clustercomp.org/2023/double_blind.html
Area 1: Application, Algorithms, and Libraries
- HPC and Big Data application studies on large-scale clusters
- Applications at the boundary of HPC and Big Data
- New applications for converged HPC/Big Data clusters
- Application-level performance and energy modeling and measurement
- Novel algorithms on clusters
- Hybrid programming techniques in applications and libraries (e.g., MPI+X)
- Cluster benchmarks
- Application-level libraries on clusters
- Effective use of clusters in novel applications
- Performance evaluation tools
Area 2: Architecture, Network/Communications, and Management
- Node and system architecture for HPC and Big Data clusters
- Architecture for converged HPC/Big Data clusters
- Energy-efficient cluster architectures
- Packaging, power and cooling
- Accelerators, reconfigurable and domain-specific hardware
- Heterogeneous clusters
- Interconnect/memory architectures
- Single system/distributed image clusters
- Administration, monitoring and maintenance tools
 Area 3: Programming and System Software
- Cluster system software/operating systems
- Programming models for converged HPC/Big Data/Machine Learning systems
- System software supporting the convergence of HPC, Big Data, and Machine Learning processing
- Cloud-enabling cluster technologies and virtualization
- Energy-efficient middleware
- Cluster system-level protocols and APIs
- Cluster security
- Management of local, center-wide and disaggregate resources and job
- Programming and software development environments on clusters
- Fault tolerance and high-availability
Area 4: Data, Storage, and Visualization
- Cluster architectures for Big Data storage and processing
- Middleware for Big Data management
- Cluster-based cloud architectures for Big Data
- Storage systems supporting the convergence of HPC and Big Data processing
- File systems and I/O libraries
- Support and integration of non-volatile memory
- Visualization clusters and tiled displays
- Big data visualization tools
- Big Data application studies on cluster architectures
Paper Submission
Submissions must be in PDF format and must conform to the following Xplore layout, page limit, and font size.
Submissions are required to be no more than 10 pages (excluding references).
Submissions must be single-spaced, 2-column numbered pages in IEEE Xplore format (8.5x11-inch paper, margins in inches – top: 0.75, bottom: 1.0, sides:0.625, and between columns:0.25, main text: 10pt).
Papers will be reviewed double-blind. Author names and affiliations should NOT be included in the submitted paper. For additional guidelines read the double blind review policy.
LaTeX and Word Templates are available here
Only web-based submissions are allowed.
Please submit your paper via the online submission system
Important Dates
Submission site open: March 1, 2023
Full Papers due: May 11, 2023
Paper Acceptance Notification: July 5, 2023
Camera-ready deadline: July 25, 2023
Conference: October 31-November 3, 2023
All deadlines are Anywhere on Earth (AoE)
Contact
Program Co-Chairs
Frank Mueller, North Carolina State University, USA
Sunita Chandrasekaran, University of Delaware, USA
More information about the hpc-announce mailing list
