[hpc-announce] CFP: 4th International Workshop on Extreme-Scale Storage and Analysis (ESSA 2023) in conjunction with IEEE IPDPS 2023, St-Petersburg, Florida, USA
François Tessier francois.tessier at inria.fr
Fri Dec 2 09:57:18 CST 2022
[Apologies if you got multiple copies of this email.]
                         CALL FOR PAPERS
         ESSA 2023: 4th International Workshop on Extreme-Scale Storage
and Analysis
             (Formerly HPS: International Workshop on High Performance
Storage)
         Held in conjunction with IPDPS 2023 - May, 2023, St.
Petersburg, Florida USA
         Submission website: https://ssl.linklings.net/conferences/ipdps/
         Submission deadline: January 21, 2023
         Workshop website: https://sites.google.com/view/essa-2023/
=== *Overview* ===
Advances in storage are becoming increasingly critical because workloads
on high performance computing (HPC) and cloud systems are producing and
consuming more data than ever before, and the situation promises to only
increase in future years. Additionally, the last decades have seen
relatively few changes in the structure of parallel file systems, and
limited interaction between the evolution of parallel file systems and
I/O support systems that take advantage of hierarchical storage layers.
However, recently the community has seen a large uptick in innovations
in data storage and processing systems as well as in I/O support
software for several reasons:
   * Technology: The availability of an increasing number of persistent
solid-state storage and persistent storage-class memory technologies
that can replace either memory or disk are creating new opportunities
for the structure of storage systems.
   * Performance requirements: Disk-based parallel file systems cannot
satisfy the performance needs of high-end systems. However, it is not
clear how solid-state storage and storage-class memory can best be used
to achieve the needed performance, so new approaches for using
solid-state storage and storage-class memory in HPC systems are being
designed and evaluated.
   * Application evolution: Data analysis applications, including graph
analytics and machine learning, are becoming increasingly important both
for scientific computing and for commercial computing.  I/O is often a
major bottleneck for such applications, both in cloud and HPC
environments – especially when fast turnaround or integration of heavy
computation and analysis are required. Consequently, data storage, I/O
and processing requirements are evolving, as complex workflows involving
computation, analytics and learning emerge.
   * Infrastructure evolution: HPC technology will not only be deployed
in dedicated supercomputing centers in the future. "Embedded HPC", "HPC
in the box", "HPC in the loop", "HPC in the cloud", "HPC as a service",
and "near-to-real-time simulation" are concepts requiring new
small-scale deployment environments for HPC. A federation of systems and
functions with consistent mechanisms for managing I/O, storage, and data
processing across all participating systems will be required to create
what is called a "computing continuum".
   * Virtualization and disaggregation: As virtualization and
disaggregation become broadly used in cloud and HPC computing, the issue
of virtualized storage has increasing importance and efforts will be
needed to understand its implications for performance.
Our goals in the ESSA Workshop are to bring together expert researchers
and developers in data-related areas such as storage, I/O, processing
and analytics on extreme scale infrastructures including HPC systems,
clouds, edge systems or hybrid combinations of these, to discuss
advances and possible solutions to the new challenges we face. We expect
the ESSA Workshop to result in lively interactions over a wide range of
interesting topics, including:
  * Extreme-scale storage systems (on high-end HPC infrastructures,
    clouds, or hybrid combinations of them)
  * Extreme-scale parallel and distributed storage architectures
  * The synergy between different storage models (POSIX file system,
    object storage, key-value, row-oriented, and column-oriented databases)
  * Structures and interfaces for leveraging persistent solid-state
  * High-performance I/O libraries and services
  * I/O performance in extreme-scale systems and applications
    (HPC/clouds/edge)
  * Storage and data processing architectures and systems for hybrid
    HPC/cloud/edge infrastructures, in support of complex workflows
    potentially combining simulation and analytics
  * Integrating computation into the memory and storage hierarchy to
    facilitate in-situ and in-transit data processing
  * I/O characterization and data processing techniques for application
    workloads relying on extreme-scale parallel/distributed
    machine-learning/deep learning
  * Tools and techniques for managing data movement among compute and
    data intensive components
  * Data reduction and compression
  * Failure and recovery of extreme-scale storage systems
  * Benchmarks and performance tools for extreme-scale I/O
  * Language and library support for data-centric computing
  * Storage virtualization and disaggregation
  * Ephemeral storage media and consistency optimizations
  * Storage architectures and systems for scalable stream-based processing
  * Study cases of I/O services and data processing architectures in
    support of various application domains (bioinformatics, scientific
    simulations, large observatories, experimental facilities, etc.)
=== *Submission Guidelines* ===
The workshop will accept traditional research papers (8-10 pages) for
in-depth topics and short papers (4-8 pages) for work in progress on hot
topics. Papers should present original research and provide sufficient
background material to make them accessible to the broader community.
Paper format: single-spaced double-column pages using 10-point size font
on 8.5x11 inch pages (IEEE conference style), including figures, tables,
and references. The submitted manuscripts should include author names
and affiliations. The IEEE conference style templates for MS Word and
LaTeX provided by IEEE eXpress Conference Publishing are available here:
https://www.ieee.org/conferences/publishing/templates.html
Submission site: https://ssl.linklings.net/conferences/ipdps/
=== *Important Dates* ===
  * Abstract submission (optional) deadline: January 14, 2023
  * Paper submission deadline: January 21, 2023
  * Acceptance notification: February 21, 2023
  * Camera-ready deadline: February 28, 2023
  * Workshop date: May 15, 2023
=== *Organization* ===
Workshop Chairs
   Kento Sato, RIKEN, Japan - Chair - kento.sato at riken.jp
   Gabriel Antoniu, Inria, France  - Co-Chair - gabriel.antoniu at inria.fr
Program Chairs
   Weikuan Yu, Florida State University, USA - Chair - yuw at cs.fsu.edu
   Sarah Neuwirth, Goethe University Frankfurt, Germany - Co-Chair -
s.neuwirth at em.uni-frankfurt.de
Web & Publicity Chair
   François Tessier, Inria, France - Chair - francois.tessier at inria.fr
Program Committee
   Gabriel Antoniu, French Insitute for Research in Computer Science and
Automation (INRIA), France
   Jean Luca Bez, Lawrence Berkeley National Laboratory (LBNL), USA
   Suren Byna, Lawrence Berkeley National Laboratory (LBNL), USA
   Wei Der Chien, University of Edinburgh, Great Britain
   Alexandru Costan, French Insitute for Research in Computer Science
and Automation (INRIA), France
   Hariharan Devarajan, Lawrence Livermore National Laboratory (LLNL),
Illinois Institute of Technology, USA
   Matthieu Dorier, Argonne National Laboratory (ANL), USA
   Hideyuki Kawashima, Keio University, Tokio, Japan
   Younjae Kim, Sogang University, South Korea
   Christos Kozanitis, Foundation for Research and Technology - Hellas
(FORTH), Greece
   Jay Lofstead, Sandia National Laboratories, USA
   Ricardo Macedo, INESC TEC, University of Minho, Portugal
   Hiroki Ohtsuji, Fujitsu Ltd, Japan
   Arnab K. Paul, PITS Pilani, K.K. Goa Campus, India
   Dana Petcu, West University of Timisoara, Romania
   Michael Schoettner, Duesseldorf University, Germany
   Chen Wang, Lawrence Livermore National Laboratory (LLNL), USA
For additional details, see  web site:
More information about the hpc-announce mailing list
