[hpc-announce] Call for Submissions IO500 ISC 2022 list
IO500 Committee committee at io500.org
Wed Apr 13 11:19:17 CDT 2022
Stabilization Period: Monday, April 4th - Friday, April 15th
Submission Deadline: Friday, May 13th, 2022 AoE
The IO500 is now accepting and encouraging submissions for the upcoming
10th semi-annual IO500 list, in conjunction with ISC-HPC'22. Once again,
we are also accepting submissions to the 10 Node Challenge to encourage
the submission of small scale results. The new ranked lists will be
announced via live-stream during "The IO500 and the Virtual Institute of
I/O" BoF [1]. We hope to see many new results.
What's New
With ISC'22, we are proposing a separation of the list into separate
Production and Research lists, to better reflect the important
distinction between storage systems that run in production environments
and those that may use more experimental hardware and software
configurations.
Since ISC'21, the IO500 follows a two-staged approach. First, there will
be a two-week stabilization period during which we encourage the
community to verify that the benchmark runs properly on a variety of
storage systems. During this period the benchmark may be updated based
upon feedback from the community. The final benchmark will then be
released. We expect that runs compliant with the rules made during the
stabilization period will be valid as a final submission unless a
significant defect is found.
We are now creating a more detailed schema to describe the hardware and
software of the system under test and provide the first set of tools to
ease capturing of this information for inclusion with the submission.
Further details will be released on the submission page [2].
We are evaluating the inclusion of optional test phases for additional
key workloads - split easy/hard find phases, 4KB and 1MB random
read/write phases, and concurrent metadata operations. This is called an
extended run. At the moment, we collect the information to verify that
additional phases do not significantly impact the results of a standard
run and an extended run to facilitate comparisons between the existing
and new benchmark phases. In a future release, we may include some or
all of these results as part of the standard benchmark. The extended
results are not currently included in the scoring of any ranked list.
Background
The benchmark suite is designed to be easy to run and the community has
multiple active support channels to help with any questions. Please note
that submissions of all sizes are welcome; the site has customizable
sorting, so it is possible to submit on a small system and still get a
very good per-client score, for example. Additionally, the list is about
much more than just the raw rank; all submissions help the community by
collecting and publishing a wider corpus of data. More details below.
Following the success of the Top500 in collecting and analyzing
historical trends in supercomputer technology and evolution, the IO500
was created in 2017, published its first list at SC17, and has grown
continually since then. The need for such an initiative has long been
known within High-Performance Computing; however, defining appropriate
benchmarks has long been challenging. Despite this challenge, the
community, after long and spirited discussion, finally reached consensus
on a suite of benchmarks and a metric for resolving the scores into a
single ranking.
The multi-fold goals of the benchmark suite are as follows:
Maximizing simplicity in running the benchmark suite
Encouraging optimization and documentation of tuning parameters for
performance
Allowing submitters to highlight their "hero run" performance numbers
Forcing submitters to simultaneously report performance for challenging
IO patterns.
Specifically, the benchmark suite includes a hero-run of both IOR and
mdtest configured however possible to maximize performance and establish
an upper-bound for performance. It also includes an IOR and mdtest run
with highly prescribed parameters in an attempt to determine a lower
performance bound. Finally, it includes a namespace search as this has
been determined to be a highly sought-after feature in HPC storage
systems that has historically not been well-measured. Submitters are
encouraged to share their tuning insights for publication.
The goals of the community are also multi-fold:
Gather historical data for the sake of analysis and to aid predictions
of storage futures
Collect tuning information to share valuable performance optimizations
across the community
Encourage vendors and designers to optimize for workloads beyond "hero
runs"
Establish bounded expectations for users, procurers, and administrators
10 Node I/O Challenge
The 10 Node Challenge is conducted using the regular IO500 benchmark,
however, with the rule that exactly 10 client nodes must be used to run
the benchmark. You may use any shared storage with any number of
servers. When submitting for the IO500 list, you can opt-in for
"Participate in the 10 compute node challenge only", then we will not
include the results into the ranked list. Other 10-node node submissions
will be included in the full list and in the ranked list. We will
announce the result in a separate derived list and in the full list but
not on the ranked IO500 list at io500.org.
Birds-of-a-Feather
Once again, we encourage you to submit [2] to join our community, and to
attend our BoF "The IO500 and the Virtual Institute of I/O" [1], where
we will announce the new IO500 and 10 node challenge lists. The current
list includes results from twenty different storage system types and 70
institutions. We hope that the upcoming list grows even more.
[1] https://io500.org/pages/bof-isc22
[2] https://io500.org/submission
The IO500 Committee
More information about the hpc-announce mailing list
