[hpc-announce] IEEE Cluster 2022 -- Call for Papers -- May 13, 2022
Kevin Brown kevin.brown.jm at gmail.com
Mon Apr 4 16:43:15 CDT 2022
         IEEE Cluster 2022 - Call for Papers
   September 6-9, 2022, Heidelberg, Germany
             https://clustercomp.org/2022/
       *** Full Papers due: May 13, 2022 ***
Review the double-blind review policy:
https://clustercomp.org/2022/double_blind.html
IEEE Cluster 2022 is the 24th edition of the IEEE Cluster conference
series, organized in cooperation with SIGHPC.
Clusters remain the primary system architecture for building many of
today’s rapidly evolving computing infrastructures and are used to solve
some of the most complex problems. The challenges to make them scalable,
efficient, productive, and increasingly effective requires a community
effort in the areas of cluster system design, advancing the capabilities of
the software stack, system management and monitoring, and the design of
algorithms, methods, and applications to leverage the overall
infrastructure.
Following the successes of previous IEEE Cluster conferences, for IEEE
Cluster 2022, which will be held September 5 - 8, 2022 in Heidelberg,
Germany, we again solicit high-quality original work that advances the
state-of-the-art in clusters and closely related fields.
All papers will be rigorously peer-reviewed for their originality,
technical depth and correctness, potential impact, relevance to the
conference, and quality of presentation. Research papers must clearly
demonstrate novel research contributions while papers reporting experiences
must clearly describe the lessons learned and the resulting impact, along
with the utility of the approach in comparison to previous work.
Authors must indicate the primary topic area of their submissions from the
four topic areas provided below. In addition, they may optionally rank
their paper relative to the overall set of topics. The papers may be
submitted as either a full 10-page paper or as a shorter 4-page paper
submission. Please note that references are not counted in the limits on
the number of pages and a 10-page submission may be accepted with a caveat
of transforming it into a 4-page version for presentation at the conference.
IEEE Cluster 2022 will use a **double-blind review process**, which is a
change from previous years. For an explanation of this process, please
refer to the following link: https://clustercomp.org/2022/double_blind.html
AREA 1: Application, Algorithms, and Libraries
 - HPC and Big Data application studies on large-scale clusters
 - Applications at the boundary of HPC and Big Data
 - New applications for converged HPC/Big Data clusters
 - Application-level performance and energy modeling and measurement
 - Novel algorithms on clusters
 - Hybrid programming techniques in applications and libraries (e.g., MPI+X)
 - Cluster benchmarks
 - Application-level libraries on clusters
 - Effective use of clusters in novel applications
 - Performance evaluation tools
AREA 2: Architecture, Network/Communications, and Management
 - Node and system architecture for HPC and Big Data clusters
 - Architecture for converged HPC/Big Data clusters
 - Energy-efficient cluster architectures
 - Packaging, power and cooling
 - Accelerators, reconfigurable and domain-specific hardware
 - Heterogeneous clusters
 - Interconnect/memory architectures
 - Single system/distributed image clusters
 - Administration, monitoring and maintenance tools
AREA 3: Programming and System Software
 - Cluster system software/operating systems
 - Programming models for converged HPC/Big Data/Machine Learning systems
 - System software supporting the convergence of HPC, Big Data, and Machine
Learning processing
 - Cloud-enabling cluster technologies and virtualization
 - Energy-efficient middleware
 - Cluster system-level protocols and APIs
 - Cluster security
 - Resource and job management
 - Programming and software development environments on clusters
 - Fault tolerance and high-availability
AREA 4: Data, Storage, and Visualization
 - Cluster architectures for Big Data storage and processing
 - Middleware for Big Data management
 - Cluster-based cloud architectures for Big Data
 - Storage systems supporting the convergence of HPC and Big Data processing
 - File systems and I/O libraries
 - Support and integration of non-volatile memory
 - Visualization clusters and tiled displays
 - Big data visualization tools
 - Programming models for Big Data processing
 - Big Data application studies on cluster architectures
Paper Submission
 - Submissions must be in PDF format and must conform to the following
Xplore layout, page limit, and font size.
 - Submissions are required to be no more than 10 pages (excluding
references).
 - Submissions must be single-spaced, 2-column numbered pages in IEEE
Xplore format (8.5x11-inch paper, margins in inches – top: 0.75, bottom:
1.0, sides:0.625, and between columns:0.25, main text: 10pt).
 - Papers will NOT be reviewed double-blind. Author names and affiliations
should be included in the submitted paper, and appropriate citations of
prior work must be included.
 - LaTeX and Word Templates are available here:
http://www.ieee.org/conferences_events/conferences/publishing/templates.html
 - Only web-based submissions are allowed.
 - Please submit your paper via the online submission system:
https://ssl.linklings.net/conferences/ieeecluster/
Important Dates
 - Submission site open: March 1, 2022
 - Full Papers due: May 13, 2022
 - Paper Acceptance Notification: July 4, 2022
 - Camera-ready deadline: July 25, 2022
 - Conference: September 5-8, 2022
 - All deadlines are Anywhere on Earth (AoE)
Contact
Chairs
 - Trilce Estrada, University of New Mexico, USA
 - Torsten Hoefler, ETH Zürich, Switzerland
Complete committee list is available here:
https://clustercomp.org/2022/committees/index.html
More information about the hpc-announce mailing list
