[hpc-announce] New ComSIS issue: Parallel Computing, Edge Computing, Advances in DB and IS
Marcin Paprzycki marcin at amu.edu.pl
Fri Jan 1 05:24:51 CST 2021
ComSIS SCI Journal: http://www.comsis.org/index.php
Two-year impact factor (2019): 0.927.
Five-year impact factor (2019): 0.775.
Volume 17, Issue 3 (October 2020) - Special Sections:
Special Section: Parallel Computing and Applications
A New Model for Predicting the Attributes of Suspects
Chuyue Zhang, Xiaofan Zhao, Manchun Cai, Dawei Wang and Luzhe Cao
An Improved Heuristic-Dynamic Programming Algorithm for Rectangular
Cutting Problem
Aihua Yin, Chong Chen, Dongping Hu, Jianghai Huang and Fan Yang
Energy-Efficient Non-linear K-barrier Coverage in Mobile Sensor Network
Zijing Ma, Shuangjuan Li, Longkun Guo and Guohua Wang
Maximize Concurrent Data Flows in Multi-radio Multi-channel Wireless
Mesh Networks
Zhanmao Cao, Qisong Huang and Chase Q. Wu
An Improved MCB Localization Algorithm Based on Weighted RSSI and Motion
Prediction
Chunyue Zhou, Hui Tian and Baitong Zhong
Special Section: Edge Computing
VDRF: Sensing the Defect Information to Risk Level of Vehicle Recall
based on Bert Communication Model
Xindong You, Jiangwei Ma, Yuwen Zhang, Xueqiang Lv and Junmei Han
A Homomorphic-encryption-based Vertical Federated Learning Scheme for
Rick Management
Wei Ou, Jianhuan Zeng, Zijun Guo, Wanqin Yan, Dingwan Liu and Stelios
Fuentes
A Novel Data-Driven Intelligent Computing Method for the Secure Control
of a Benchmark Microgrid System
Shunjiang Wang, Yan Zhao, He Jiang, Rong Chen and Lina Cao
A Recommendations Model with Multiaspect Awareness and Hierarchical
User-Product Attention Mechanisms
Zhongqin Bi, Shuming Dou, Zhe liu and Yongbin Li
A Study on the Development of a Light Scattering Particulate Matter
Sensor and Monitoring System
Jun-hee Choi and Hyun-Sug Cho
A Load Balancing Scheme for Gaming Server applying Reinforcement
Learning in IoT
Hye-Young Kim and Jin-Sul Kim
Graph Embedding Code Prediction Model Integrating Semantic Features
Kang Yang, Huiqun Yu, Guisheng Fan and Xingguang Yang
Special Section: Advances in Databases and Information Systems
Improving the Performance of Process Discovery Algorithms by Instance
Selection
Mohammadreza Fani Sani, Sebastiaan J. van Zelst and Wil van der Aalst
Crowd counting á la Bourdieu, Automated estimation of the number of people
Karolina Przybylek and Illia Shkroba
Visual E-Commerce Values Filtering Framework with Spatial Database metric
M. Kopecky and P. Vojtas
Ta wiadomość została sprawdzona na obecność wirusów przez oprogramowanie antywirusowe Avast.
https://www.avast.com/antivirus
More information about the hpc-announce mailing list
