[hpc-announce] C3PO Workshop at ISC 2021 - Deadline Extended
Bangalore, Purushotham puri at uab.edu
Thu Apr 1 14:56:17 CDT 2021
C3PO Workshop - Second workshop on Compiler-assisted Correctness Checking and Performance Optimization for HPC
held in conjunction with ISC 2021
*Virtual event*
Friday, July 2, 2021
https://c3po-workshop.github.io/2021/index
Abstract
C3PO is a new workshop at the intersection of compilers/translators, HPC middleware, and HPC applications. Practical compiler-enabled programming environments, applied analysis methodologies, and end-to-end toolchains are crucial to performance portability in the exascale era. The workshop brings together researchers with a shared interest in applying compilation and source-to-source translation methodologies to enhance parallel programming, including explicit programming models such as MPI, OpenMP, and hybrid models.
Original papers will identify and solve challenges in the tradeoffs of scalability, performance, predictability, correctness, productivity, and portability on-node and at massive scale. Strong-scaling, weak-scaling, and hybrid-scaling solutions assisted, augmented, and/or enabled by compiler technology are in scope.
We recognize that there are standard static analysis technologies (dataflow analysis, polyhedral analysis, etc); this workshop seeks innovative applications of such technologies to derive enhanced utility in parallel programs that are generalizable beyond a single case study or narrow application.
The workshop solicits contributions in the following (but not limited to) topics:
* Automatic parallelization
* Compilation for heterogeneous systems
* Compiler enabled optimization
* Compilation techniques for correctness checking of parallel software
* Cross-languages translation
* Modernization of legacy codes
* Source code instrumentation
* Source-to-source analysis/transformations
* Static analysis
* Static/dynamic interaction
Submission
C3PO solicits two kinds of papers. Full papers present novel and original research and are limited to 12 pages in Springer LNCS format. Short papers report on interesting new ideas, work with promising/early results, or empirical studies and are limited to 6 pages in Springer LNCS format.
The review process is double blind. Each submission will receive at least three reviews.
Papers must be submitted in PDF format on the submission website. The organizers will make informal proceedings available online before the conference. Authors may submit a revised version of the paper after the workshop for printed proceedings. Authors of accepted papers will be required to sign the Springer copyright form. Instructions for preparing papers for the proceedings will be emailed to authors of accepted papers.
Submission Website: https://easychair.org/conferences/?conf=c3po21
Important Dates
Paper submissions due: April 7, 2021 (AoE)
Notification of acceptance: May 7, 2021
Camera-ready papers due: TBD
Looking forward to your participation. We hope to see you virtually for C3PO 2021!
Best regards,
The C3PO workshop Organizers
More information about the hpc-announce mailing list
