[hpc-announce] CFP: AsHES 2021, The Eleventh International Workshop on Accelerators and Hybrid Emerging Systems
SIMON GARCIA DE GONZALO simon.garcia at bsc.es
Mon Nov 16 09:36:58 CST 2020
[Apologies if you got multiple copies of this email. If you'd like to
opt-out of these
announcements, information on how to unsubscribe is available at the
bottom of this email.]
CALL FOR PAPER
Systems (AsHES)
https://pmodels.github.io/ashes-www/2021/index.html
May 17th, 2021
With PARCO Special Issue
To be held in conjunction with 35th IEEE International Parallel and
Distributed Processing Symposium
Portland, Oregon USA
Workshop Scope and Goals
The current computing landscape has gone through an ever-increasing rate
of change and innovation. This change has been driven by the relentless
need to improve the energy-efficient, memory, and compute throughput at
all levels of the architectural hierarchy. Although the amount of data
that has to be organized by today's systems posed new challenges to the
architecture, which can no longer be solved with classical, homogeneous
design. Improvements in all of those areas have led Heterogeneous
systems to become the norm rather than the exception.
Heterogeneous computing leverages a diverse set of computing (CPU, GPU,
FPGA, TPU ...) and Memory (HBM, Persistent Memory, Coherent PCI
protocols, etc ..), hierarchical storage systems and units to accelerate
the execution of a diverse set of applications. Emerging and existing
areas such as AI, BigData, Cloud Computing, Edge-Computing, Real-time
systems, High-Performance Computing, and others have seen a real benefit
due to Heterogenous computer architectures. These new heterogeneous
architectures often also require the development of new applications and
programming models, in order to satisfy these new architectures and to
fully utilize these capacities. This workshop focuses on understanding
the implications of heterogeneous designs at all levels of the computing
system stack, such as hardware, compiler optimizations, porting of
applications, and developing programming environments for current and
emerging systems in all the above-mentioned areas. It seeks to ground
heterogeneous system design research through studies of application
kernels and/or whole applications, as well as shed light on new tools,
libraries and runtime systems that improve the performance and
productivity of applications on heterogeneous systems.
The goal of this workshop is to bring together researchers and
practitioners who are at the forefront of Heterogeneous computing in
order to learn the opportunities and challenges in future Heterogeneous
system design trends and thus help influence the next trends in this
area.
Topics of interest for the full paper (8 - 10 pages) track submissions
include (but are not limited to):
* Strategies for programming heterogeneous systems using high-level
models such as OpenMP, OpenACC, SYCL, low-level models such as OpenCL,
CUDA;
* Methods and tools to tackle challenges from heterogeneity in AI/ML/DL,
BigData, Cloud Computing, Edge-Computing, Real-time Systems, and
High-Performance Computing;
* Strategies for application behavior characterization and performance
optimization for accelerators;
* Techniques for optimizing kernels for execution on GPGPU, FPGA, TPU,
and emerging heterogeneous platforms;
* Models of application performance on heterogeneous and accelerated HPC
systems;
* Compiler Optimizations and tuning heterogeneous systems including
parallelization, loop transformation, locality optimizations,
Vectorization;
* Implications of workload characterization in heterogeneous and
accelerated architecture design;
* Benchmarking and performance evaluation for heterogeneous systems at
all level of the system stack;
* Tools and techniques to address both performance and correctness to
assist application development for accelerators and heterogeneous
processors;
* System software techniques to abstract application domain-specific
functionalities for accelerators;
A short paper track (maximum of 6 pages) has been added to this year’s
program to highlight early investigations of innovative ideas in
emerging selected topics such as:
* Innovative use of heterogeneous computing in AI for science or
optimizations for AI
* Heterogeneous computing at Edge
* Design and use of domain-specific functionalities on accelerators
Important Dates (AoE)
Paper Submission: Jan. 25, 2021 (AoE)
Paper Notification: Feb. 20, 2021 (AoE)
Proceedings
The proceedings of this workshop will be published electronically
together with IPDPS proceedings via the IEEE Xplore Digital Library.
Papers Submission Guidelines
Papers should present original research and should provide sufficient
background material to make them accessible to the broader community.
Regular paper track submitted manuscripts may not exceed 10
single-spaced double-column pages using 10-point size font on 8.5x11
inch pages (IEEE conference style), including figures, tables, and
references. See the style templates for latex or word for details.
Short paper track submitted manuscripts follow the same instructions as
the regular manuscript but may not exceed 6 pages.
Submissions will be judged based on relevance, significance,
originality, correctness, and clarity.
Submission site: https://easychair.org/conferences/?conf=ashes2021
Journal Special Issue
The best papers of AsHES 2021 will be invited to a Special Issue on
Topics on Heterogeneous Computing of the Elsevier International Journal
on Parallel Computing (PARCO).
Steering Committee
Pavan Balaji, Argonne National Laboratory, USA
Yunquan Zhang, Chinese Academy of Sciences, China
Satoshi Matsuoka, Tokyo Institute of Technology, Japan
Jiayuan Meng, Argonne National Laboratory, USA
Xiaosong Ma, Qatar Computing Research Institute, Qatar
Barbara Chapman, Stony Brook University, USA
Guang R. Gao, University of Delaware, USA
Xinmin Tian, Intel, USA
Michael Wong, Codeplay, UK
James Dinan, Intel Corporation
Sunita Chandrasekaran, University of Delaware, USA
Antonio J. Peña, Barcelona Supercomputing Center, Spain
General Chair
Min Si, Argonne National Laboratory, USA
Program Co-Chairs
Lena Oden, FernUni Hagen, Germany
Simon Garcia de Gonzalo, Barcelona Supercomputing Center, Spain
Program Committee
Guray Ozen, NVIDIA, USA
Adrián Castelló, Universitat Jaume I, Spain
Leonel Toledo, Barcelona Supercomputing Center, Spain
Pedro Valero-Lara, Cray, a Hewlett Packard Enterprise company, USA
John Leidel, Texas Tech University, USA
Paul F. Baumeister, Jülich Supercomputing Centre
Seyong Lee, Oak Ridge National Laboratory, USA
Ashwin M. Aji, AMD, USA
Stephen Olivier, Sandia National Laboratories, USA
Gabriele Jost, NASA Ames Research Center/CSRA, USA
Guido Juckeland, Helmholtz-Zentrum Dresden-Rossendorf (HZDR), Germany
Huimin Cui, Institute of Computing Technology, CAS, China
Gaurav Mitra, Texas Instruments Inc., USA
Nikela Papadopoulou, National Technical University of Athens, Greece
Bronis de Supinski, Lawrence Livermore National Laboratory, USA
Questions?
Please send any queries about the AsHES workshop to ashes at mcs.anl.gov
Dr. Simon Garcia De Gonzalo
Postdoctoral Researcher and STARS 2020 Fellow
Accelerators and Communications for HPC
Barcelona Supercomputing Center (BSC)
http://bsc.es/disclaimer
More information about the hpc-announce mailing list
