[hpc-announce] CFP: Special Issue on "Programming for Heterogeneous and Embedded Computing" ( Electronics journal)
Arturo Gonzalez-Escribano
arturo at infor.uva.es
Mon Nov 2 04:29:42 CST 2020
Dear Colleagues,
Please, consider to submit a paper for the Special Issue "Programming
for Heterogeneous and Embedded Computing" in the Open Access journal
Electronics (ISSN 2079-9292). Recently, its IF has increased to 2.412,
ranking 125/266 (Q2) in 'Engineering, Electrical & Electronic' according
to JCR report 2020.
Check the special issue page on:
https://www.mdpi.com/journal/electronics/special_issues/PHEC
Many computing platforms are currently combining different kinds of
computing devices in the same system. They can include multicore CPUs
with complex memory hierarchies, massive accelerators such as GPUs,
specialized computing units for specific fields such as deep learning,
or reconfigurable hardware devices such as FPGAs. These different types
of devices are combined to build a range of systems from high-end
supercomputers to embedded consumer-electronics systems.
Programming high-performance applications that exploit such parallel,
complex, and heterogeneous machines is challenging; it frequently
requires a mix of different programming models and languages and is
plagued by architecture dependent decisions that compromise portability.
New programming models and tools are being proposed. Nevertheless, there
is still a long way to go to achieve simple, homogeneous, and productive
programming environments for this diverse computing landscape.
Contributions on all layers of programming and execution systems for
heterogeneous computing are key to develop high-performance applications
on modern and future computing platforms.
The aim of this Special Issue is to promote advancement in the following
topics:
* Heterogeneous programming, including multicore CPUs, accelerators,
and/or domain specific architectures;
* Parallel programming models and languages;
* High-level system synthesis techniques;
* High-performance compiling and code generation;
* Run-time systems for heterogeneous platforms;
* Parallel programming, debugging, and profiling tools;
* Programming for resilience;
* Code and performance portability;
* Reconfigurable and embedded computing;
* New programming and computing paradigms.
Research articles, review articles as well as short communications are
invited. All papers will be peer-reviewed. Accepted papers will be
published continuously in the journal (as soon as accepted) and will be
listed together on the special issue website. Manuscripts can be
submitted until the deadline: 31 January 2021.
Dr. Arturo Gonzalez-Escribano
Dr. Yuri Torres
/Guest Editors/
-- Arturo González Escribano ------------------------------------------
-- eMail: arturo[at]infor.uva.es --------------------------------------
-- Departamento de Informática. Universidad de Valladolid -------------
-- Telf: (+34) - 983 - 185613 -----------------------------------------
-- Fax: (+34) - 983 - 423671 -----------------------------------------
More information about the hpc-announce
